Contacting HomeSeer This Week
See more
See less
Event Lag?
  • Event Lag?
    Hi All,
    I wonder if you can help. I seem to be having an issue where my Homeseer seems to suffer lag.
    It's just happened today, but happened last night also. Suddenly my Homeseer speaker will start spewing out speech like it's suddenly catching up with itself. Events that should have triggered hours ago, suddenly fire off all at once. Please see the log below. You'll notice the log goes dead at 15:29 then goes mental from 16:02. The weird thing is, if I turn on a device, it seems to still respond, so we have no idea until we get the speech spew that anything's gone wrong.
    Homeseer version: HS3 Standard Edition 3.0.0.435 (Windows)
    Dec-11 16:15:50         Event    Event Trigger "Bulb Monitoring Standard Lamp ON"
    Dec-11 16:15:50         Event    Event Trigger "Bulb Monitoring Lounge Lamp ON"
    Dec-11 16:15:00         Log Info    The log database is currently 12.45MB in size.
    Dec-11 16:15:00         Log Maintenance    195 records, selected by date/time, were removed from the log database.
    Dec-11 16:12:33         Z-Wave    Device: Node 5 Hidden Watts Set to 10.008 (10.008 Watts)
    Dec-11 16:12:33         Z-Wave    Device: Lighting Hidden Wall Light (kW Hours) Set to 75.662 (75.662 kW Hours)
    Dec-11 16:11:07         River Level    Oath - No change since last update.
    Dec-11 16:11:06         Rain    No recorded rain.
    Dec-11 16:11:06         Rain    txtcurrent: 0
    Dec-11 16:11:06         Event    Running script in background: C:/Program Files/HomeSeer HS3/scripts/Rain.vb
    Dec-11 16:11:06         Event    Running script in background: C:/Program Files/HomeSeer HS3/scripts/Oath.vb
    Dec-11 16:11:06         Event    Event Trigger "Data Collection River Levels"
    Dec-11 16:11:06         Event    Event Trigger "Data Collection Rain Alert"
    Dec-11 16:10:35         Event    Event Trigger "Bulb Monitoring Standard Lamp ON"
    Dec-11 16:10:35         Event    Event Trigger "Bulb Monitoring Lounge Lamp ON"
    Dec-11 16:07:20         TTS    Speak ():A ticket has been updated.
    Dec-11 16:07:20         Event    Event Trigger "Email Events Updated Ticket"
    Dec-11 16:06:33         Z-Wave    Device: Node 5 Hidden Watts Set to 9.377 (9.377 Watts)
    Dec-11 16:05:26         Z-Wave    Device: Lighting Front Door Wall Light Set to 255
    Dec-11 16:05:26         Z-Wave Error    Failed sending Z-Wave command to device: Lighting Kitchen Kitchen Lights
    Dec-11 16:05:25         Event    Event Trigger "Bulb Monitoring Standard Lamp ON"
    Dec-11 16:05:25         Event    Event Trigger "Bulb Monitoring Lounge Lamp ON"
    Dec-11 16:05:25         Event    Event Trigger "Bulb Monitoring Lounge Lamp OFF"
    Dec-11 16:05:22         Event    Event Trigger "Bulb Monitoring Standard Lamp ON"
    Dec-11 16:05:22         Event    Event Trigger "Bulb Monitoring Lounge Lamp ON"
    Dec-11 16:05:21         River Level    Oath - No change since last update.
    Dec-11 16:05:20         Rain    No recorded rain.
    Dec-11 16:05:20         Rain    txtcurrent: 0
    Dec-11 16:05:20         Event    Running script in background: C:/Program Files/HomeSeer HS3/scripts/Oath.vb
    Dec-11 16:05:20         Event    Running script in background: C:/Program Files/HomeSeer HS3/scripts/Rain.vb
    Dec-11 16:05:20         Event    Event Trigger "Data Collection Rain Alert"
    Dec-11 16:05:20         Event    Event Trigger "Data Collection River Levels"
    Dec-11 16:05:20         Z-Wave    Device: Lighting Lounge Lamp Set to 50
    Dec-11 16:05:20         Event    Event Trigger "Bulb Monitoring Standard Lamp ON"
    Dec-11 16:05:20         Event    Event Trigger "Bulb Monitoring Lounge Lamp ON"
    Dec-11 16:05:20         Z-Wave    Device: Lighting Lounge Standard Lamp Set to 60
    Dec-11 16:05:19         Z-Wave    Device: Lighting Side Entrance Lamp Set to 255
    Dec-11 16:05:19         Device Control    Device: Lighting Front Door Wall Light to On (255)
    Dec-11 16:05:19         Device Control    Device: Lighting Kitchen Kitchen Lights to On (255)
    Dec-11 16:05:19         Device Control    Device: Lighting Lounge Lamp to Dim 50% (50)
    Dec-11 16:05:19         Device Control    Device: Lighting Lounge Standard Lamp to Dim 60% (60)
    Dec-11 16:05:19         Event    Event Trigger "Standard Events Sunset Devices Bedtime Aware"
    Dec-11 16:05:19         Device Control    Device: Lighting Side Entrance Lamp to On (255)
    Dec-11 16:05:19         Device Control    Device: Lighting Central Garden Gate Lights to On (100)
    Dec-11 16:05:19         Event    Event Trigger "Standard Events Sunset Devices"
    Dec-11 16:05:17         TTS    Speak ():A new ticket has been received.
    Dec-11 16:05:17         Device Control    Device: Outputs Node 0 CCTV Input 2 (PIR) to Off (0)
    Dec-11 16:05:17         Event    Event Trigger "Email Events New Ticket"
    Dec-11 16:05:16         Device Control    Device: Outputs Node 0 CCTV Input 2 (PIR) to On (1)
    Dec-11 16:05:16         Event    Event Trigger "Standard Events CCTV PIR"
    Dec-11 16:05:15         Event    Event Trigger "Bulb Monitoring Standard Lamp ON"
    Dec-11 16:05:15         Event    Event Trigger "Bulb Monitoring Lounge Lamp ON"
    Dec-11 16:05:12         Event    Event Trigger "Bulb Monitoring Standard Lamp ON"
    Dec-11 16:05:12         Event    Event Trigger "Bulb Monitoring Lounge Lamp ON"
    Dec-11 16:05:12         Event    Event Trigger "Standard Events Sunset Timer"
    Dec-11 16:05:12         River Level    Oath - No change since last update.
    Dec-11 16:05:11         Rain    No recorded rain.
    Dec-11 16:05:11         Rain    txtcurrent: 0
    Dec-11 16:05:11         Event    Running script in background: C:/Program Files/HomeSeer HS3/scripts/Rain.vb
    Dec-11 16:05:11         Event    Event Trigger "Data Collection Rain Alert"
    Dec-11 16:05:11         Event    Running script in background: C:/Program Files/HomeSeer HS3/scripts/Oath.vb
    Dec-11 16:05:11         Event    Event Trigger "Data Collection River Levels"
    Dec-11 16:05:10         Event    Event Trigger "Bulb Monitoring Standard Lamp ON"
    Dec-11 16:05:10         Event    Event Trigger "Bulb Monitoring Lounge Lamp ON"
    Dec-11 16:05:09         TTS    Speak ():Gate door opened.
    Dec-11 16:05:09         Device Control    Device: Outputs Node 0 CCTV Input 2 (PIR) to Off (0)
    Dec-11 16:05:09         Device Control    Device: Outputs Node 0 CCTV Input 1 (Gate Door) to Off (0)
    Dec-11 16:05:08         Device Control    Device: Outputs Node 0 CCTV Input 2 (PIR) to On (1)
    Dec-11 16:05:08         Event    Event Trigger "Standard Events CCTV PIR"
    Dec-11 16:05:08         Device Control    Device: Outputs Node 0 CCTV Input 1 (Gate Door) to On (1)
    Dec-11 16:05:08         Event    Event Trigger "Broadcasts Gate Door Open"
    Dec-11 16:05:08         Event    Event Trigger "Bulb Monitoring Lounge Lamp ON"
    Dec-11 16:05:08         Event    Event Trigger "Bulb Monitoring Standard Lamp ON"
    Dec-11 16:05:07         TTS    Speak ():There is some body at the door.
    Dec-11 16:05:06         Device Control    Device: Outputs Node 0 CCTV Input 3 (Front Door) to Off (0)
    Dec-11 16:05:06         TTS    Speak ():Network Alert. The backup NAZ is offline.
    Dec-11 16:05:06         Event    Event Trigger "Network Alerts Network Alert: Backup NAS"
    Dec-11 16:05:05         Device Control    Device: Outputs Node 0 CCTV Input 3 (Front Door) to On (1)
    Dec-11 16:05:05         Event    Event Trigger "Broadcasts Doorbell"
    Dec-11 16:05:05         TTS    Speak ():A ticket has been updated.
    Dec-11 16:05:05         Event    Event Trigger "Email Events Updated Ticket"
    Dec-11 16:05:02         Device Control    Device: Lighting Lounge Lamp to Off (0)
    Dec-11 16:05:02         Event    Event Trigger "Bulb Monitoring Lounge Lamp Monitor"
    Dec-11 16:05:02         Z-Wave    Device: Lighting Lounge Lamp Set to 0
    Dec-11 16:05:02         Event    Event Trigger "Bulb Monitoring Standard Lamp ON"
    Dec-11 16:05:02         Event    Event Trigger "Bulb Monitoring Lounge Lamp ON"
    Dec-11 16:05:02         River Level    Oath - No change since last update.
    Dec-11 16:05:01         Rain    No recorded rain.
    Dec-11 16:05:01         Rain    txtcurrent: 0
    Dec-11 16:05:01         Event    Running script in background: C:/Program Files/HomeSeer HS3/scripts/Rain.vb
    Dec-11 16:05:01         Event    Event Trigger "Data Collection Rain Alert"
    Dec-11 16:05:01         Event    Running script in background: C:/Program Files/HomeSeer HS3/scripts/Oath.vb
    Dec-11 16:05:01         Event    Event Trigger "Data Collection River Levels"
    Dec-11 16:04:58         TTS    Speak ():A ticket has been updated.
    Dec-11 16:04:58         Event    Event Trigger "Email Events Updated Ticket"
    Dec-11 16:04:53         River Level    Oath - No change since last update.
    Dec-11 16:04:53         Rain    No recorded rain.
    Dec-11 16:04:53         Event    Running script in background: C:/Program Files/HomeSeer HS3/scripts/Oath.vb
    Dec-11 16:04:53         Event    Event Trigger "Data Collection River Levels"
    Dec-11 16:04:53         Rain    txtcurrent: 0
    Dec-11 16:04:53         Event    Running script in background: C:/Program Files/HomeSeer HS3/scripts/Rain.vb
    Dec-11 16:04:53         Event    Event Trigger "Data Collection Rain Alert"
    Dec-11 16:04:51         TTS    Speak ():A ticket has been updated.
    Dec-11 16:04:48         Event    Event Trigger "Email Events Updated Ticket"
    Dec-11 16:04:43         River Level    Oath - No change since last update.
    Dec-11 16:04:42         Rain    No recorded rain.
    Dec-11 16:04:42         Rain    txtcurrent: 0
    Dec-11 16:04:42         Event    Running script in background: C:/Program Files/HomeSeer HS3/scripts/Rain.vb
    Dec-11 16:04:42         Event    Event Trigger "Data Collection Rain Alert"
    Dec-11 16:04:42         Event    Running script in background: C:/Program Files/HomeSeer HS3/scripts/Oath.vb
    Dec-11 16:04:42         Event    Event Trigger "Data Collection River Levels"
    Dec-11 16:04:11         TTS    Speak ():A ticket has been updated.
    Dec-11 16:04:08         Event    Event Trigger "Email Events Updated Ticket"
    Dec-11 16:04:07         River Level    Oath - No change since last update.
    Dec-11 16:04:05         Rain    No recorded rain.
    Dec-11 16:04:05         Rain    txtcurrent: 0
    Dec-11 16:04:05         Event    Running script in background: C:/Program Files/HomeSeer HS3/scripts/Rain.vb
    Dec-11 16:04:05         Event    Event Trigger "Data Collection Rain Alert"
    Dec-11 16:04:05         Event    Running script in background: C:/Program Files/HomeSeer HS3/scripts/Oath.vb
    Dec-11 16:04:05         Event    Event Trigger "Data Collection River Levels"
    Dec-11 16:03:17         TTS    Speak ():A new ticket has been received.
    Dec-11 16:03:15         Event    Event Trigger "Email Events New Ticket"
    Dec-11 16:03:14         TTS    Speak ():A new ticket has been received.
    Dec-11 16:03:11         Event    Event Trigger "Email Events New Ticket"
    Dec-11 16:03:11         River Level    Oath - No change since last update.
    Dec-11 16:03:10         Rain    No recorded rain.
    Dec-11 16:03:10         Rain    txtcurrent: 0
    Dec-11 16:03:10         Event    Running script in background: C:/Program Files/HomeSeer HS3/scripts/Rain.vb
    Dec-11 16:03:10         Event    Event Trigger "Data Collection Rain Alert"
    Dec-11 16:03:10         Event    Running script in background: C:/Program Files/HomeSeer HS3/scripts/Oath.vb
    Dec-11 16:03:10         Event    Event Trigger "Data Collection River Levels"
    Dec-11 16:03:08         TTS    Speak ():A ticket has been updated.
    Dec-11 16:03:04         Event    Event Trigger "Email Events Updated Ticket"
    Dec-11 16:03:02         River Level    Oath - No change since last update.
    Dec-11 16:03:01         Rain    No recorded rain.
    Dec-11 16:03:01         Rain    txtcurrent: 0
    Dec-11 16:03:01         Event    Running script in background: C:/Program Files/HomeSeer HS3/scripts/Rain.vb
    Dec-11 16:03:01         Event    Event Trigger "Data Collection Rain Alert"
    Dec-11 16:03:01         Event    Running script in background: C:/Program Files/HomeSeer HS3/scripts/Oath.vb
    Dec-11 16:03:01         Event    Event Trigger "Data Collection River Levels"
    Dec-11 16:02:56         River Level    Oath - No change since last update.
    Dec-11 16:02:54         Rain    No recorded rain.
    Dec-11 16:02:54         Rain    txtcurrent: 0
    Dec-11 16:02:54         Event    Running script in background: C:/Program Files/HomeSeer HS3/scripts/Rain.vb
    Dec-11 16:02:54         Event    Event Trigger "Data Collection Rain Alert"
    Dec-11 16:02:54         Event    Running script in background: C:/Program Files/HomeSeer HS3/scripts/Oath.vb
    Dec-11 16:02:54         Event    Event Trigger "Data Collection River Levels"
    Dec-11 16:02:49         Device Control    Device: Outputs Node 0 CCTV Input 2 (PIR) to Off (0)
    Dec-11 16:02:49         River Level    Oath - No change since last update.
    Dec-11 16:02:48         TTS    Speak ():A ticket has been updated.
    Dec-11 16:02:48         Device Control    Device: Outputs Node 0 CCTV Input 2 (PIR) to On (1)
    Dec-11 16:02:48         Event    Event Trigger "Standard Events CCTV PIR"
    Dec-11 16:02:47         Rain    No recorded rain.
    Dec-11 16:02:47         Rain    txtcurrent: 0
    Dec-11 16:02:47         Event    Running script in background: C:/Program Files/HomeSeer HS3/scripts/Oath.vb
    Dec-11 16:02:47         Event    Running script in background: C:/Program Files/HomeSeer HS3/scripts/Rain.vb
    Dec-11 16:02:47         Event    Event Trigger "Data Collection Rain Alert"
    Dec-11 16:02:47         Event    Event Trigger "Data Collection River Levels"
    Dec-11 16:02:45         Event    Event Trigger "Email Events Updated Ticket"
    Dec-11 16:02:42         TTS    Speak ():A new ticket has been received.
    Dec-11 16:02:39         Event    Event Trigger "Email Events New Ticket"
    Dec-11 16:02:39         River Level    Oath - No change since last update.
    Dec-11 16:02:38         Rain    No recorded rain.
    Dec-11 16:02:38         Rain    txtcurrent: 0
    Dec-11 16:02:38         Event    Running script in background: C:/Program Files/HomeSeer HS3/scripts/Oath.vb
    Dec-11 16:02:38         Event    Running script in background: C:/Program Files/HomeSeer HS3/scripts/Rain.vb
    Dec-11 16:02:38         Event    Event Trigger "Data Collection River Levels"
    Dec-11 16:02:38         Event    Event Trigger "Data Collection Rain Alert"
    Dec-11 16:02:35         TTS    Speak ():A new ticket has been received.
    Dec-11 16:02:32         River Level    Oath - No change since last update.
    Dec-11 16:02:31         Event    Event Trigger "Email Events New Ticket"
    Dec-11 16:02:29         Rain    No recorded rain.
    Dec-11 16:02:29         Rain    txtcurrent: 0
    Dec-11 16:02:29         Event    Running script in background: C:/Program Files/HomeSeer HS3/scripts/Rain.vb
    Dec-11 16:02:29         Event    Event Trigger "Data Collection Rain Alert"
    Dec-11 16:02:29         Event    Running script in background: C:/Program Files/HomeSeer HS3/scripts/Oath.vb
    Dec-11 16:02:29         Event    Event Trigger "Data Collection River Levels"
    Dec-11 15:29:17         Z-Wave    Device: Node 3 Hidden General Purpose Alarm 2 Set to OFF
    Dec-11 15:29:17         Z-Wave    Device: Security Front Door Doorbell Set to OFF
    Dec-11 15:29:17         Z-Wave    Device: Node 3 Hidden General Purpose Alarm 2 Set to ON
    Dec-11 15:29:17         Z-Wave    Device: Security Front Door Doorbell Set to ON
    Dec-11 15:28:03         Z-Wave    Device: Lighting Lounge Lamp Set to 99
    Dec-11 15:28:03         Z-Wave    Device: Lighting Lounge Standard Lamp Set to 99
    Dec-11 15:28:02         Device Control    Device: Lighting Lounge Lamp to On (99) by/from: CAPI Control Handler
    Dec-11 15:28:02         Device Control    Device: Lighting Lounge Standard Lamp to On (99) by/from: CAPI Control Handler
    Dec-11 15:27:57         Z-Wave    Device: Appliances Lounge AV Equipment Set to 0
    Dec-11 15:27:57         Device Control    Device: Appliances Lounge AV Equipment to Off (0) by/from: CAPI Control Handler
    Dec-11 13:54:38         Z-Wave    Device: Appliances Lounge AV Equipment Set to 255
    Dec-11 13:54:38         Device Control    Device: Appliances Lounge AV Equipment to On (255) by/from: CAPI Control Handler
    Dec-11 13:40:25         Error    Unable to connect to POP server(1) outlook.office365.com Error: Tried to read a line. Only '' received. Please make sure that antivirus and firewall software are disabled or configured correctly.
    Dec-11 13:25:32         Error    Unable to connect to POP server(1) outlook.office365.com Error: Tried to read a line. Only '' received. Please make sure that antivirus and firewall software are disabled or configured correctly.
    Dec-11 13:15:00         Log Info    The log database is currently 12.45MB in size.
    Dec-11 13:15:00         Log Maintenance    270 records, selected by date/time, were removed from the log database.
    Dec-11 13:07:06         Energy DB Info    All energy database compacting routines completed.
    Dec-11 13:07:06         Energy DB    Database is 56.63672 MB in size. No further compaction needed.
    Dec-11 13:06:34         Energy DB Info    Compacting remaining data...
    Dec-11 13:06:21         Energy DB Info    Compacting data older than 4 months...
    Dec-11 13:06:07         Energy DB Info    Compacting data older than 1 year...
    Dec-11 13:06:00         Energy DB Info    Compacting data older than 3 years...
    Dec-11 13:06:00         Energy DB Info    Compacting data older than 5 years...
    Dec-11 13:06:00         Energy DB Info    Compacting data older than 10 years...
    Dec-11 13:06:00         Energy DB Info    Energy database compaction initiated.
    Dec-11 12:56:07         River Level    Oath - No change since last update.
    Dec-11 12:56:06         Rain    No recorded rain.
    Dec-11 12:56:06         Rain    txtcurrent: 0
    Dec-11 12:56:06         Event    Running script in background: C:/Program Files/HomeSeer HS3/scripts/Rain.vb
    Dec-11 12:56:06         Event    Running script in background: C:/Program Files/HomeSeer HS3/scripts/Oath.vb
    Dec-11 12:56:06         Event    Event Trigger "Data Collection Rain Alert"
    Dec-11 12:56:06         Event    Event Trigger "Data Collection River Levels"
    Dec-11 12:41:07         River Level    Oath - No change since last update.
    Dec-11 12:41:06         Rain    No recorded rain.
    Dec-11 12:41:06         Rain    txtcurrent: 0
    Dec-11 12:41:06         Event    Running script in background: C:/Program Files/HomeSeer HS3/scripts/Rain.vb
    Dec-11 12:41:06         Event    Event Trigger "Data Collection Rain Alert"
    Dec-11 12:41:06         Event    Running script in background: C:/Program Files/HomeSeer HS3/scripts/Oath.vb
    Dec-11 12:41:06         Event    Event Trigger "Data Collection River Levels"
    Dec-11 12:34:22         TTS    Speak ():There is some body at the door.
    Dec-11 12:34:20         Device Control    Device: Outputs Node 0 CCTV Input 3 (Front Door) to Off (0)
    Dec-11 12:34:19         Z-Wave    Device: Node 3 Hidden General Purpose Alarm 2 Set to OFF
    Dec-11 12:34:19         Z-Wave    Device: Security Front Door Doorbell Set to OFF
    Dec-11 12:34:19         Z-Wave    Device: Node 3 Hidden General Purpose Alarm 2 Set to ON
    Dec-11 12:34:19         Device Control    Device: Outputs Node 0 CCTV Input 3 (Front Door) to On (1)
    Dec-11 12:34:19         Event    Event Trigger "Broadcasts Doorbell"
    Dec-11 12:34:19         Z-Wave    Device: Security Front Door Doorbell Set to ON
    Dec-11 12:30:02         TTS    Speak ():Network Alert. The backup NAZ is offline.
    Dec-11 12:30:00         Event    Event Trigger "Network Alerts Network Alert: Backup NAS"
    Dec-11 12:26:07         River Level    Oath - No change since last update.
    Dec-11 12:26:06         Rain    No recorded rain.
    What version of Homeseer are you running?
      Doh, rookie mistake
        Do you have a speech proxy enabled?
        HS3 Pro Edition 3.0.0.548
          Not that I am aware of.. not heard of speed proxy before.
          But.. it's not just speech. I thought it was initially, but it appears to be event (which drives all the speech). For example, we have an IO board then triggers and event.. that will be delayed also.
            I suspect there may be a problem with communication to a peripheral that is causing the system to hang until a timeout occurs. (If you had a speech proxy, I would also suspect that it was hanging, but you don't.) Could it be your IO board interface? Do you have any way to monitor it?
