Strange issues with "Last Working Route:"
  • #46
    Other than Rich has said he doesn’t know when he will put it on the schedule.
    Ill post more later.
    • #47
      Thats too bad. I've purchased a Homeseer Z-Net (EU version with UZB) that I can't use.
      • #48
        As far as I know HS does have UZBs, I'm assuming it's made by Z-Wave.ms, to test with. One would also assume that both the US and EU versions have the same commands.
        What I don't know is if HS has a RaZberry to work with. Heck, if they don't then I'll trade mine for a FC200
        One big advantage with the RaZberry is that you can install an external antenna. So if you have a larger house you can add a 3dbi antenna and get better coverage without having to route. I was planing to put together an Open Source Z-NET which would be both POE powered and have an external antenna. That way as long as one can get a ethernet cable to it you can place it anywhere even if there isn't an outlet nearby. This can also be done with an HS Z-Net less the external antenna.
