Creating text message event
  • Creating text message event
    I was trying to follow this How-to so that I would get a text message if my garage door opens:
    https://forums.homeseer.com/forum/ho...-values-in-hs3
    I got as far as trying to create an event. It asked me for a group name, which I called Garage Door. Once I get to the IF, I don't have any option to select the garage door open event. What steps am I missing?
    Since you are new to HS, I would suggest looking at the examples that HS user rprade has put together in the event clinic:
    https://forums.homeseer.com/forum/ho...t-clinic-forum
    https://forums.homeseer.com/forum/ho...tents?t=172984
      Thank you! It's actually tricky to find the right help when there is so much around!
        Once you have a handle on creating events and get this working, you may want to look into the free pushover plugin.
        https://forums.homeseer.com/forum/ho...ushover-plugin
        For most (but not all) use cases it beats text messages for notifications from HomeSeer.
          I had some success in setting up the event, but it has not worked. Also, while rprade has put together a great user guide for events, the "send an e-mail" chapter is "to be created". I thought I had everything set up, but I guess I either have something wrong or am still missing something. I may have learned enough to get it figured out though. Joegr, I'll definitely be looking into the pushover plugin.
          One thing I didn't realize when I got the zee s2 was that plugins are not limited to the automation technology. So while I thought I'd only ever need two plugins (z-wave and Insteon), I might be using more. Hopefully I won't outgrow the zee too quickly!
          Edit: Got it. I had to go into setup>email and enter my email address.
          Now to get it to send a text
            Did you configure your email settings under Tools - Setup - E-Mail?
              That was the problem. Done and fixed. I've even got it sending me a text now. I'm happy for now!
                On some basic usage (i think) regarding texts to a cell, why are all texts received of HS3 from different numbers (1410200515, 1410200015, 1410200012, 141020000514, etc)? I've tried looking thru headers (when emailing) and can't quite figure out. Not using gmail so I can't blame goggle (using MS 365). Using BlueIris, all texting to my cell comes from one addy/number, which is configurable, making things easy on a cell; but thru HS3 I'm sure there's a reason, explanation & work-around for all the individual numbers but for now just testing my enviro, I have to open every damn text to see past 'SUBJ:' which is kinda ineff.
                Haven't gotten to read the pdf on the pushover p[lugin....yet; though perhaps something simple needs another plugin/interface...
