Increasing Handles and HS Server crashes
  • #31
    Nevermind, found it.
    I actually show 1770-1780 when running everything (pretty close to what Proc Mon says):
    Arduino
    Blue-Iris
    CONCORD
    Device History
    EasyTrigger
    JowiHue
    mcsMQTT
    RFXCOM
    Sonos
    weatherXML
    Z-Wave
    Events seem to have a largest effect on my number of handles. I run an avg number of events, nothing spectacular, very few recurring (and not every x secs), almost all triggered by external device or script.
    Z
    • #32
      Originally posted by vasrc View Post
      What arguments are you passing for handle64.exe so I see the same.
      Z
      I'm running handle.exe as HS3 is a 32 bit process, but not sure if it matters. I'm running the following:
      handle.exe -s -p HS3
      • #33
        I believe events in the context of a handle mean something different than a HS3 event.
        • #34
          Also, dedicated Win 7 machine, i5 processor, 8gb ram.
          • #35
            I'm similar: W7 Pro, i7 quad core, 8gb ram
            • #36
              You have a clear thread handle leak. Or if that’s valid something went crazy and created thousands of threads. Each requires its own stack and that is a lot of memory. I’d loop Rich into this convo, probably firing off threads and not disposing the handles properly later.
              • #37
                rjh Hi Rich, any advise on ways to troubleshoot this (besides turning off plugins and events and waiting)?
                Al
                • #38
                  Originally posted by Uncle Michael View Post
                  Update: My handles count appears to have leveled off with WeatherXML disabled, but the time span is too short to draw a firm conclusion. Will continue to monitor.
                  Hi UM, any update? Have you tried Squeezebox as well?
                  Al
                  • #39
                    First I would update to the latest release build 500.
                    Check the Windows system event viewer and see if any crashes are listed there, sometimes there is useful info.
                    Al
                    • #40
                      I re-enabled the WeatherXML plug-in last evening. It appears that most, though not all, of my handles increase is coming from that, but compared to what you are seeing it is insignificant. (The time scale on the magenta graph is from ~9:50 AM 2/2 to 9:20 AM 2/4. The blue vertical marks are when the plug-in was disabled and re-enabled. The second graph is just the time when the plug-in was disabled.)
                      I looked at SB some time ago, but concluded at that time that it wasn't a significant contributor. I haven't checked it lately, but my handles increase is not of particular practical concern with my current hardware.
                      Click image for larger version  Name:	Handles 0950_2_2_0920_2_4.PNG Views:	1 Size:	4.1 KB ID:	1282233Click image for larger version  Name:	Handles0940_1620_0203.PNG Views:	1 Size:	4.9 KB ID:	1282234
                      HS3 Pro Edition 3.0.0.548
                      • #41
                        I'm wondering if could be OS related? I'm running on Windows 2016 Server as a Fire Daemon service and my handles both increase and decrease.
                        Robert.
                        • #42
                          Thanks Rich, updated to .500, but so far that has not helped. Most of the Thread Handles and Event Handles show as "READ_CONTROL|DELETE|SYNCHRONIZE|WRITE-DAC|WRITE_OWNER|THREAD_ALL_ACCESS". Does that provide any clues as to possible causes?
                          Al
                          Click image for larger version  Name:	Capture.PNG Views:	1 Size:	90.9 KB ID:	1282293
                          • #43
                            Thanks!
                            • #44
                              It's possible. I used to see this on my XP system as well, but I'm assuming there are others that are running W7 that are not having this issue.
                              • #45
                                No, that does not help. It could file reads, or I/O stuff. I would disable some plugins until it goes away, most likely its a plugin doing something, or a plugin causing HS3 to do something it normally does not do.
                                Al
