Increasing Handles and HS Server crashes
  • #46
    No, that does not help. It could file reads, or I/O stuff. I would disable some plugins until it goes away, most likely its a plugin doing something, or a plugin causing HS3 to do something it normally does not do.
    That's what I've been trying to do (currently but also in the past), but there does not appear to be a smoking gun. Any possibility a script or scripts are the cause? Any do's or don't associated with scripts to ensure they don't cause this?
    • #47
      Rich plugins can’t create threads in HSConsole to the thread leak is somewhere in your code or libraries you use.
      • #48
        Originally posted by sparkman View Post
        Thanks Rich, updated to .500, but so far that has not helped. Most of the Thread Handles and Event Handles show as "READ_CONTROL|DELETE|SYNCHRONIZE|WRITE-DAC|WRITE_OWNER|THREAD_ALL_ACCESS". Does that provide any clues as to possible causes?
        Al
        Click image for larger version Name:	Capture.PNG Views:	1 Size:	90.9 KB ID:	1282293
        Can you please expand the name field on those threads. That may be a huge hint.
        • #49
          Most of them are blank. The HS3 ones in the screen shot show HS3.exe (29024): xxxxx, where xxxx appear to be sequential numbers.
          • #50
            I have disabled the plugins shown in bold below and now my handles are steady at around 3500. I'll leave it overnight to see if they stay around that level and then will slowly start re-enabling those. I'm leaning towards DSC Security and/or X10 being the culprits as my handle leak preceded me running all of the other plugins in that list that are still disabled. For Jon00HTML2Image, I've reduced the use of it as I was using it to generate images for my SqueezeBox Radio screen savers based on web pages generated by HS' web server. Therefore the issue could also be related to it.
            APCUPSD, BLLED, BLTVGuide, Chromecast ,DSC Security, EasyTrigger, Homekit bridge, IFTTT, ImperiHome, MQTT, MySensors, PHLocation2, Pushover 3P, Random, Restart, RFXCOM, SDJ-Health, SqueezeBox, Ultra1Wire3, UltraGCIR3, UltraLog3, UltraNetCam3, UltraPioneerAVR3, weatherXML, X10, Z-Wave, Jon00SpeedFanMonitor, Jon00ProcessMonHS3, Jon00DBChartingHS3, Jon00SNMPMonitor, Jon00HTML2Image
            • #51
              Al, I'm running the X-10 plugin as well and doubt very much that's causing it. I noticed others with increasing handles using the DCS plugin which I don't run.
              Robert
              • #52
                Thanks and agreed, but I do need to prove it and it may be potentially an issue with a combination of plugins. I disabled the ones which were the least impact to my HA. The handles did start creeping up again, so I need to disable a few more.
                • #53
                  There is no place where a plugin can directly create threads in HS other than if they do so in their constructor when first loaded into HS to check capabilities (plugins are loaded into the HSConsole to call these settings, then unloaded and ran remotely). Plugin authors have been told to not do this, and if they did the bump would only happen when the plugin first loaded. So while a plugin may be 'triggering' the creation of an HS thread, causing the leak, I do not believe you will find a single plugin responsible. Most likely there is an API in HS which launches the thread (the HS.GetURL is a potential candidate) and some plugins may use such a function more than others... So ideally we need to narrow down the type of functionality the plugins that seem responsible share to help narrow down the root cause.
                  • #54
                    Thanks Bill. Funny that you mention hs.geturl as I do have a few scripts calling that on a regular basis. I feel like I'm chasing ghosts though, as I've tried all this in the past and was never successful at poinpointing the issue. Short of disabling all my events and plugins and enabling them one at a time and then waiting for a day or two, there does not seem anyway to resolve this. And I don't have the patience for that, nor the time. rjh Can you comment on the points made? I disabled more plugins, events calling certain scripts, etc. and thought the handles were stable, but then they start increasing again.
                    • #55
                      I have never created the handles issue here in the office, users have fixed it by making changes to their system. It is an I/O issue though so you must have something that is constantly accessing I/O like the network, serial ports, or some other I/O device. Also, I seem to remember some simply changing to a different PC and the problem went away. Do you have another PC you can try, maybe a laptop? All you need to do is copy over your entire HS3 folder to another system to test.
                      • #56
                        Thanks, I had the issue on my old PC as well. I had other issues that went away when I moved to this system, but not the handle leak.
                        • #57
                          rjh Rich, these are thread handles, so dubious of your IO statement (e.g. these aren't files left open, ports, etc, these are threads that the HSConsole process creates or is created in its process space by a dll you use) Could you add descriptive thread names in the places in your code where you explicitly start threads? That would potentially help narrow this down. If the thread names are know, we know where to look, if not we know its likely a library we need to dive into.
                          • #58
                            Long ago I made sure all of HS3 threads have names, so you should see a name if HS3 created the thread.
                            • #59
                              I'm not clear the difference between threads and handles and handles to threads. The screen shots I posted are of handles. Most of the handles are related to threads and events and most don't have a name and the ones that do are very generic, so no way to pinpoint.
                              • #60
                                A thread is unit of execution, often the lowest one in an OS (albeit some support fibers, which are a way of sharing a single thread). Typically one thread can operate at a time per CPU core you have, so if you have 4 cores 4 threads will be running (internally the OS will context swap so you may have 400 threads on those 4 cores with each getting 1/100th of the CPU time per second). A thread handle is just an opaque piece of data that you can use to tell the OS which thread you want to perform an action on. One can, for example, suspend or terminate a thread. Typically the API calls to do this take a thread handle, so they know which of the N threads in the system you are referring to. When a thread exits the handle can stay valid (when queried it would show the thread was done), so while the threads may have run to completion, the question is why aren't the handles being closed (free'd) so they are not building up.
