Scripting: Any way of getting a "label" not just a "value"?
  • Scripting: Any way of getting a "label" not just a "value"?
    Today, for example, I have an occupancy variable (as a device) that can have values 0 to 3. On the device page, labels appear such as Unoccupied or Probably Occupied.
    When I use scripting, however, I see now way to look up the label (e.g., "Unoccupied") given the value (e.g., 0).
    Ideas?
    You can use hs.CAPIGetStatus(xxxx) where xxxx is the reference id of the device.
      Full code:
        Dim iRef As Integer = hs.GetDeviceRefByName("xxx")
        Dim CS As ICAPIStatus = hs.CAPIGetStatus(iRef)
        Dim sLabel As String = CS.Status
        Thanks much. Works great. I see that I can also get an image of the state. (PS: sparkman, just visited Calgary for the first time last week. It's a bit cold there!)
          Yes, it's been the coldest February in a long time. We've only had a day or two with normal seasonal temperatures and the rest have been well below.
