Contacting HomeSeer This Week
See more
See less
Cannot delete a timer plus other timer questions
  • Cannot delete a timer plus other timer questions
    Question 1: I have a timer that I would like to delete but as much as I click on the bit red "X" it will not delete. I've check everyplace to see if it's still being used and I can't find any. How do I delete this timer?
    Question 2: Is there any way to rename a timer? That way I could just reuse it.
    Question 3: Is there any way to recreate the Device that was created when a timer was created? I deleted one by accident. I'd just delete and then recreate the timer but HELPdthen we're back to Question 1
    Have you tried restarting HS and then deleting it after a restart? I think I had the same thing happen once and I was able to delete after a restart.
      Found the delete problem. There was one reference to the timer still laying around that I missed. Fixed that and I was able to delete it. Still haven’t found a solutioh to Questions 2 & 3.
        Answer to question 2: You can rename a timer, it's a pain, and it has caveats. A timer is not a reference, so if you change the name, any event that uses it will be broken.
        Rename a timer: In an event, select "If a timer becomes", then select the timer you want to rename. Then click create/edit timer, and you can edit (rename) the timer. Maybe there is another way to get there, but I found this instruction in a Bugzilla post.
          You can create, reuse or rename a timer within the configuration of an Event
          Randy Prade
          Aurora, CO
          Prades.net
            Thanks, that answers Question #2. I will say I didn’t expect expect to find at at the point of use instead of point of creation.
            So so that leaves only question #3 unanswered.
              If you enable "Create Devices for Counters and Timers" in setup, all missing devices will be created when you restart. After that, disable the setting and delete the unwanted devices.
              Randy Prade
              Aurora, CO
              Prades.net
                I guess that covers everything. Thanks
