HS3 Migration Ongoing Project.
  • #46
    Originally posted by Wadenut View Post
    This is just a midnight observation.
    I know that at one time, way back when, in HS2 I'd used Include files in scripts using the #Include statement. Perhaps back then I was using VB6 scripts, I don't remember.
    It seems though that NET no longer (or perhaps never did) supports that handy facility, and there's really no way to efficiently implement something to get around this.
    I'm using a subroutine in virtually all my scripts now that replaces hs.ExecX10, and/or hs.Transmit which often appears dozens of times in dome of my files. It's about 8 lines and I've improved it several times this past week, meaning I've had to open and re-edit every single script for consistency.
    It's too bad this was omitted in VB.NET.
    Check out this thread: https://forums.homeseer.com/forum/ho...mon-subroutine
    Jon
    • #47
      Originally posted by jon00 View Post
      Well now, isn't that special? I tried exactly that (as I'd always done before) the other day and got errors. Then I searched the net for the subject and found nothing but negative results. Now, that was back on 3....500, so now it might well work. I'll try later..
      • #48
        I've been including other script files for ages, including on .500 with no issues. Not sure why it was not working for some in the thread that Jon referenced.
        #Include includes/isholiday.vb
        Sub Main(ByVal Parms As String)
        HS 3.0.0.548: 1976 Devices 1156 Events
        Z-Wave 3.0.1.262: 123 Nodes on one Z-Net
        • #49
          I haven't tried today, but I just realized, perhaps it's the difference between \ and /. Perhaps tomorrow I'll try again. Took today off.
          • #50
            I'm thinking either / or \ would work on Windows but that / would be needed for linux.
            EDIT: Just tried it here with the slash the other way and work fine (on Windows) that way too.
            • #51
              Just tried. No go. No matter, I can live without it for now.
              • #52
                Strange. Do you get the same errors as Don in the other thread?
                • #53
                  I do actually.
                  • #54
                    Do you have a "Sub Main" in the file you are trying to include? Looking at mine, I don't have a Sub Main and also declare every function/subroutine as "Private":
                    Private Function FullMoon(whichday)
                    • #55
                      Just ran into this too trying to play back a phone message:
                      File does not exist: C:\Program Files (x86)\HomeSeer HS3\html\hspw
                      Checked. No such file or folder. Likely something I haven't set up when I configured HSPhone.
                      • #56
                        No.
                        The file was this:
                        Sub Test(Parm as Object)
                        hs.Writelog("TST","Include worked")
                        End sub
                        • #57
                          Yes, there is no such file or folder, but if HS Phone is running, it should generate a web page when you go to http://www.xxx.yyy.zzz/hspw
                          • #58
                            Try this:
                            Private Sub Test(Parm as Object)
                            End sub
                            • #59
                              Mine works without the Private as well:
                              #Include includes/test.vb
                                  hs.Writelog("TST","Did include work?")
                                  Test("123")
                              End Sub
                              End Sub
                              Mar-26 4:35:20 PM TST Include worked
                              Mar-26 4:35:20 PM TST Did include work?
                              Mar-26 4:35:19 PM Event Running script in background: C:/Program Files (x86)/HomeSeer HS3/scripts/testinclude.vb
                              • #60
                                OK, it does that, but can't play the message neither thri speaker clients or web page. Thought it might be related.
                                . So this error is expected then?
