IFTTT issue running events after upgrade to .523/.528
  • IFTTT issue running events after upgrade to .523/.528
    Hi all,
    I upgraded from .500 to .523 saturday morning and one of my IFTTT applets that runs a HS event stopped working . I was troubleshooting it this morning and get the following when trying to pick a HS event. IFTTT applets that update devices do seem to be working normally. Anyone seeing the same thing? I upgraded to .528 and still have the same issue. rjh, any ideas?
    Al
    Can anyone that uses IFTTT try to replicate this issue?
      I know this sounds odd, but I can replicate it intermittently.... Eight out of 10 times it will populate the list of events to choose from, the other 2 times it draws a blank and says options unavailable (same as your example). I'm running HS .531.
      To be honest the HS/IFTTT integration has never been 5 star for me. And it's hard to pin down which service is to blame. So I've been doing everything in my power to find alternative ways to connect devices that are not supported by HS, such as HS plugins, Mosquito, Node-Red, TCP, JSON, UDP, etc.. Normally I use a SmartThings>webCORE>Homeseer>SmartThings circle which works great (ST seems to support everything). That's how I eliminated about 150 IFTTT events involving Leviton Wifi switches.
      Altogether I've went from a few hundred IFTTT events to less than a dozen now. WAF is a whole order of magnitude better.
      --Barry
