Device address
  • Device address
    Hi,
    I have both running HS2 and HS3 running on the same HS-PC.
    Both systems are connected over the Jon00 HS2. HS3 connector. Now I want to export all my HS2 RFXcom devices from HS2 to HS3 step by step.
    The HS2 RFXcom devices are mirrored to HS3 and have the same device address code like in HS2.
    I was reading that only unused device addresses/codes can be exported by the RFXcom export - not if the same addresses/codes are used.
    What to do now ? Do I have to delete all my mirrored HS RFXcom devices in HS3 ?
    Is the export possible after changing the HS3 addresses/codes ?
    The HS3 Device adrresses are greyed out, is it possible to change the Device address ?
    Fischi
    You will probably get a more informed answer to this question if you ask it on the RFXCOM forum.
    HS3 Pro Edition 3.0.0.548
