HS3 X10 logging
  • HS3 X10 logging
    Is there a way to turn on logging of x10 devices? HS2 used to do this.
    In the HS3 GUI go to plugins / uncheck the developer mode box.
    - Pete
    Auto mator
    Homeseer 3 Pro - 3.0.0.548 (Linux) - Ubuntu 18.04/W7e 64 bit Intel Haswell CPU - Mono 6.4X
    Homeseer Zee2 (Lite) - 3.0.0.548 (Linux) - Ubuntu 18.04/W7e - CherryTrail x5-Z8350 BeeLink 4Gb BT3 Pro - Mono 6.4X
      In the configuration tab of each X10 device you want logged, look at "Do not log commands from this device:" and uncheck it if it's checked as necessary. Click Done at the bottom of the page and you should have full logging.
        Yes above meant debug logging.
        Device logging looks like this and is done the way Wadenut mentions above.
        Jul-06 7:58:16 AM Starting Plug-In Initializing plugin X10 ...
        Jul-06 7:58:16 AM Info Initializing CM11A/12U on COM port /dev/ttyUSB0
        Jul-06 7:58:17 AM Starting Plug-In Plugin X10 started successfully in 1259 milliseconds
        Jul-06 7:58:17 AM Starting Plug-In X10 loaded in 2506 milliseconds
        Jul-06 7:58:17 AM Plug-In Finished initializing plug-in X10
        Jul-06 7:58:25 AM Device Control Device: x10 x10remote A1 to On (100) by/from: CAPI Control Handler
        Debug logging looks like this:
        Jul-06 8:01:25 AM X10 DEBUG CM11A Sending: 4 66 Size: 2
        Jul-06 8:01:25 AM X10 DEBUG CM11A Got checksum: 6A
        Jul-06 8:01:25 AM X10 DEBUG CM11A Checksum OK, sending 0
        Jul-06 8:01:26 AM X10 DEBUG CM11A Got ack of: 55
        Jul-06 8:01:26 AM X10 DEBUG CM11A Sending: 6 62 Size: 2
        Jul-06 8:01:26 AM X10 DEBUG CM11A Got checksum: 68
        Jul-06 8:01:26 AM X10 DEBUG CM11A Checksum OK, sending 0
        - Pete
        Auto mator
