Can't get a HS Smart Stick+ to restore
  • Can't get a HS Smart Stick+ to restore
    I'm having a really bad day. I just received a new HS Smart Stick+ and was trying to restore my Z-Wave network to it. This is something I've done many times and never had an issue doing it.
    My first attempt at doing a restore on the HS SS+ I kept getting errors that the version was unknown. This was fixed by moving to the Beta Z-Wave Plugin.
    From that point on it goes through the motions but only device ID one gets loaded and that is the controller.
    There is a message about more than one system wanting to sue the controller but that happens only during the restore and not during a Plugin restart.
    I can control some most devices but only ones that don't need to be routed since the controller doesn't have the node information since it won't load.
    This is the file that I restored from.
    F9B23B15
    2,211,156,0,4,17,4
    3,211,156,0,4,17,4
    4,211,156,0,4,17,4
    5,211,156,0,4,17,4
    6,211,156,0,4,17,4
    7,211,156,1,4,17,1
    8,211,156,0,4,17,4
    9,211,156,0,4,17,4
    10,211,156,1,4,16,1
    11,211,156,1,4,17,1
    12,211,156,0,4,17,4
    13,211,156,0,4,17,4
    14,211,156,0,4,17,4
    15,211,156,0,4,17,4
    16,211,156,0,4,17,4
    17,209,140,0,4,17,1
    18,211,156,0,4,17,4
    19,211,156,1,4,17,1
    20,211,156,1,4,17,1
    21,211,156,1,4,17,1
    22,211,156,0,4,17,4
    23,211,156,1,4,17,1
    24,211,156,0,4,17,4
    25,211,156,0,4,17,4
    26,211,156,1,4,17,1
    27,211,156,1,4,16,1
    31,146,150,0,2,2,2
    33,211,156,0,4,17,4
    35,211,156,1,4,17,8
    36,211,156,1,4,17,1
    38,211,156,1,4,17,1
    39,211,156,1,4,17,1
    40,211,156,1,4,17,1
    41,211,156,1,4,17,1
    43,211,156,1,4,17,1
    44,211,156,1,4,17,1
    45,211,156,1,4,17,1
    46,211,156,1,4,17,1
    47,211,156,1,4,16,1
    48,211,156,0,4,17,4
    49,41,4,0,3,2,0
    51,211,156,1,4,17,1
    53,211,156,1,4,17,1
    54,211,156,1,4,16,1
    55,211,156,1,4,16,1
    56,211,156,1,4,16,1
    57,83,156,1,4,7,1
    58,211,156,1,4,16,1
    59,211,156,1,4,16,1
    60,83,156,0,4,32,1
    61,83,156,0,4,32,1
    62,83,156,0,4,32,1
    63,211,156,1,4,16,1
    64,211,156,1,4,16,1
    Log from the above Restore
    Jul-14 4:33:15 PM
    Z-Wave
    HS-SS+01 is a SUC or SIS for this network.
    Jul-14 4:33:15 PM
    Z-Wave
    HS-SS+01 Controller is static lib.
    Jul-14 4:33:15 PM
    Z-Wave
    HS-SS+01 Controller chip type is ZW050x.
    Jul-14 4:33:15 PM
    Z-Wave
    The interface's security support has been set.
    Jul-14 4:33:15 PM
    Z-Wave
    Interface RF powerlevel was successfully reset to Normal Power
    Jul-14 4:33:15 PM
    Z-Wave
    Jul-14 4:33:15 PM
    Z-Wave
    Jul-14 4:33:15 PM
    Z-Wave
    Jul-14 4:33:15 PM
    Z-Wave
    Jul-14 4:33:15 PM
    Z-Wave
    HS-SS+01: Found 1 Z-Wave nodes in interface node ID 1 (HS-SS+01)
    Jul-14 4:33:15 PM
    Z-Wave
    HS-SS+01: Z-Wave interface node ID: 1, Home ID: F9B23B15
    Jul-14 4:33:15 PM
    Z-Wave
    HS-SS+01: Z-Wave Serial API version: 8
    Jul-14 4:33:15 PM
    Z-Wave
    Jul-14 4:33:15 PM
    Z-Wave
    HS-SS+01: Z-Wave interface node ID: 1, Home ID: F9B23B15  <——————— This is the correct HomeID
    Jul-14 4:33:15 PM
    Z-Wave
    Jul-14 4:33:15 PM
    Z-Wave
    HS-SS+01: Controller firmware version: 6.4
    Jul-14 4:33:15 PM
    Z-Wave
    Jul-14 4:33:08 PM
    Z-Wave
    HS-SS+01: Getting node information from controller...
    Jul-14 4:33:08 PM
    Z-Wave
    HS-SS+01: Z-Wave Ethernet at IP 10.0.2.19, connected to interface ok.
    Jul-14 4:33:08 PM
    Z-Wave
    HS-SS+01: ----------------------------------------------------------------------
    Jul-14 4:33:08 PM
    Z-Wave
    Initializing Z-Wave interface HS-SS+01 (HomeSeer Z-NET Ethernet) at 10.0.2.19, port 2001
    Jul-14 4:33:08 PM
    Z-Wave
    Jul-14 4:33:08 PM
    Z-Wave
    HS-SS+01: ======================================================================
    Jul-14 4:33:08 PM
    Z-Wave
    HS-SS+01: Exiting Ethernet Communications Thread
    Jul-14 4:33:00 PM
    Z-Wave
    Jul-14 4:33:00 PM
    Z-Wave
    HS-SS+01: Processing data buffered by the interface while it was disconnected.
    Jul-14 4:33:00 PM
    Z-Wave
    Jul-14 4:33:00 PM
    Z-Wave Error
    HS-SS+01: Exception transmitting to IP 10.0.2.19: Unable to write data to the transport connection: The socket has been shut down.
    Jul-14 4:32:45 PM
    Z-Wave
    HS-SS+01: Restore of node information COMPLETE.
    Jul-14 4:32:25 PM
    Z-Wave Warning
    A Z-Wave interface on the system is being restarted - some Z-Wave signals could be missed.
    Jul-14 4:32:25 PM
    Z-Wave
    HS-SS+01: Node information has been successfully loaded - restarting the controller...
    Jul-14 4:32:21 PM
    Z-Wave
    HS-SS+01 has successfully been made the SIS for this network.
    Jul-14 4:32:21 PM
    Z-Wave
    HS-SS+01 attempting to set as SUC/SIS...
    Jul-14 4:32:21 PM
    Z-Wave
    HS-SS+01 is the Primary Controller for this network.
    Jul-14 4:32:21 PM
    Z-Wave
    Jul-14 4:32:21 PM
    Z-Wave
    Jul-14 4:32:21 PM
    Z-Wave
    Jul-14 4:32:21 PM
    Z-Wave
    Starting Z-Wave Polling for Network D704D83B...
    Jul-14 4:32:21 PM
    Z-Wave
    Jul-14 4:32:21 PM
    Z-Wave
    HS-SS+01: Z-Wave interface node ID: 1, Home ID: D704D83B  <——————— This is not my HomeID and I assume it’s a temp.
    Jul-14 4:32:21 PM
    Z-Wave
    Jul-14 4:32:21 PM
    Z-Wave
    Jul-14 4:32:21 PM
    Z-Wave
    HS-SS+01: Restoring Data 0...
    Jul-14 4:32:07 PM
    Z-Wave
    Jul-14 4:32:07 PM
    Z-Wave
    Jul-14 4:32:07 PM
    Z-Wave
    Jul-14 4:32:05 PM
    Z-Wave
    Saving...
    Jul-14 4:32:02 PM
    Z-Wave Warning
    Trying to re-connect to Ethernet interface at IP 10.0.2.19...
    Jul-14 4:32:02 PM
    Z-Wave
    Note: Only one system may connect to an Ethernet interface at one time. If 2 systems are connecting to your Z-Wave interface, HomeSeer will not connect.
    Jul-14 4:31:50 PM
    Z-Wave
    Jul-14 4:31:44 PM
    Z-Wave Warning
    Jul-14 4:31:39 PM
    Z-Wave
    HS-SS+01: Erase complete - sending the network ID to the interface.
    Jul-14 4:31:39 PM
    Z-Wave
    Jul-14 4:31:36 PM
    Z-Wave
    Z-Wave Interface HS-SS+01 (1) has been reset to its defaults.
    Jul-14 4:31:36 PM
    Z-Wave Warning
    HS-SS+01: Erasing the interface...
    Jul-14 4:31:36 PM
    Z-Wave
    HS-SS+01: Restoring node information from the file /opt/HomeSeer/Data/Z-Wave/Restore.ZWave. Please wait...
    Well looks like it's the Z-Net, my old ZeeS2, when running the HS-SS+. I was able to load it by plugging it into the computer. Now I'll move the card to the Z-Net and see if it runs.
      Hey John, did you get it working? Are you running HS's Z-Net build or one of mine? What is the contents of /etc/ser2net.conf, particularly the line that starts with
      2001:raw: ...
        I'm using the HS build. put everything aside for a few hours so I could think about it. Then I remembered the ser2net.conf file.
        Just checked it and it's:
        BANNER:banner:\r\nser2net port \p device \d [\s] (Debian GNU/Linux)\r\n\r\n
        #2000:telnet:600:/dev/ttyS0:9600 8DATABITS NONE 1STOPBIT banner
        2001:raw:0:/dev/ttyACM0:115200 8DATABITS NONE 1STOPBIT -XONXOFF -RTSCTS
        #2002:raw:0:/dev/ttyUSB0:19200 8DATABITS NONE 1STOPBIT -XONXOFF -RTSCTS
        #3000:telnet:600:/dev/ttyS0:19200 8DATABITS NONE 1STOPBIT banner
        #3001:telnet:600:/dev/ttyS1:19200 8DATABITS NONE 1STOPBIT banner
        Without the HS-SS+ installed. I'll move the card in the morning when I get up since I have to go into the attic.
        BTW, When I first tried this I forgot that I had put the RazBerry card in. So both it and the HS-SS+ were installed. That may have confused things. I took the card out and tried again but still had issues.
        Biggest issue right now is having the HS-SS+ in the attic effects it's range. I could try the RazBerry and add it to the network. I think that works since it gets the information from the primary device. It's something I've never tried so it's a big experiment but one that I need to try anyway since i'll be adding several Z-Wave devices to the back yard and will need better coverage there.
        I also have some HS nodes that think they are sleeping devices as I get this message on the Z-Wave tab "Note: The device must be woken up manually to use the functions below.". I've not found out how to fix this.
        OMT, The Node Information page seems to be very slow now. Don't know if it's due to the HS SS+ or something else. It basically locks up the entire web interface so you can display any other page until it's finished.
          Latest update in getting up and running. Well, I'm up but not the way I like. I had to perform the restore with the HS SS+ plugged directly into the HS3 system running on Ubuntu. I then had to move the HS SS+ back to the Z-Net so it was in the location where it can reach everything in the house fairly well. I still need to really have two Z-Nets but that a later issue I won't address untill all of my old Evolve dimmers are replaced with the 15 WD200s I just put on order.
          What I don't understand is why the HS SS+ won't restore on the Z-Net. The Z-Net is later "working" version of 1.0.23.
          Here is its current ser2net.conf file.
          I thought that ttyACM0 was for the EZZeeUS card but it seems to basically work. I just want to be able to do the restore using the Z-Net and not have to put the HS SS+ back in the main system every time I need to do it.
            Hi John, not a SmartStick, but I have a Nortek HUSBZB-1 which is the same mfgr as the SmartStick (unless that's changed in the past year or so). I was able to restore the file you posted above without issue. Log below. Afterwards Node Information shows 55 nodes.
            I notice this is using Z-Wave version 3.0.2.234, which is what came with HS3-Pi. Next I'll try the main line 3.0.1.252.
            I am running my own build, which has a more recent ser2net than that on the HS Z-Net.
            Jul-22 8:56:32 PM Z-Wave Security S2 Support Is Enabled
            Jul-22 8:56:32 PM Z-Wave Z-Nyt HUSBZB-1 is the SIS for the network.
            Jul-22 8:56:32 PM Z-Wave Z-Nyt HUSBZB-1 There is a SUC/SIS in the network.
            Jul-22 8:56:32 PM Z-Wave Z-Nyt HUSBZB-1 Controller is static lib.
            Jul-22 8:56:32 PM Z-Wave Z-Nyt HUSBZB-1 Controller chip type is ZW050x.
            Jul-22 8:56:32 PM Z-Wave The interface's security support has been set.
            Jul-22 8:56:32 PM Z-Wave Z-Nyt HUSBZB-1: Found 55 Z-Wave nodes in interface node ID 1 (Z-Nyt HUSBZB-1)
            Jul-22 8:56:32 PM Z-Wave Z-Nyt HUSBZB-1: Z-Wave interface node ID: 1, Home ID: F9B23B15
            Jul-22 8:56:32 PM Z-Wave Z-Nyt HUSBZB-1: Z-Wave Serial API version: 5
            Jul-22 8:56:31 PM Z-Wave Z-Nyt HUSBZB-1: Controller firmware version: 4.32
            Jul-22 8:56:28 PM Z-Wave Z-Nyt HUSBZB-1: Getting node information from controller...
            Jul-22 8:56:28 PM Z-Wave Z-Nyt HUSBZB-1: Z-Wave Ethernet at IP 192.168.1.118, connected to interface ok.
            Jul-22 8:56:28 PM Z-Wave Z-Nyt HUSBZB-1: ----------------------------------------------------------------------
            Jul-22 8:56:28 PM Z-Wave Initializing Z-Wave interface Z-Nyt HUSBZB-1 (Ethernet Interface) at 192.168.1.118, port 2003
            Jul-22 8:56:28 PM Z-Wave Z-Nyt HUSBZB-1: ======================================================================
            Jul-22 8:56:28 PM Z-Wave Z-Nyt HUSBZB-1: Exiting Ethernet Communications Thread
            Jul-22 8:56:24 PM Z-Wave Z-Nyt HUSBZB-1: Restore of node information COMPLETE.
            Jul-22 8:56:24 PM Z-Wave Z-Nyt HUSBZB-1: Controller firmware version: 4.32
            Jul-22 8:56:19 PM Z-Wave Warning A Z-Wave interface on the system is being restarted - some Z-Wave signals could be missed.
            Jul-22 8:56:19 PM Z-Wave Z-Nyt HUSBZB-1: Node information has been successfully loaded - restarting the controller...
            Jul-22 8:56:15 PM Z-Wave Z-Nyt HUSBZB-1: Restoring node information for node 64...
            Jul-22 8:56:14 PM Z-Wave Z-Nyt HUSBZB-1: Restoring node information for node 63...
            Jul-22 8:56:14 PM Z-Wave Z-Nyt HUSBZB-1: Restoring node information for node 62...
            Jul-22 8:56:14 PM Z-Wave Z-Nyt HUSBZB-1: Restoring node information for node 61...
            Jul-22 8:56:14 PM Z-Wave Z-Nyt HUSBZB-1: Restoring node information for node 60...
            Jul-22 8:56:14 PM Z-Wave Z-Nyt HUSBZB-1: Restoring node information for node 59...
            Jul-22 8:56:14 PM Z-Wave Z-Nyt HUSBZB-1: Restoring node information for node 58...
            Jul-22 8:56:14 PM Z-Wave Z-Nyt HUSBZB-1: Restoring node information for node 57...
            Jul-22 8:56:13 PM Z-Wave Z-Nyt HUSBZB-1: Restoring node information for node 56...
            Jul-22 8:56:13 PM Z-Wave Z-Nyt HUSBZB-1: Restoring node information for node 55...
            Jul-22 8:56:13 PM Z-Wave Z-Nyt HUSBZB-1: Restoring node information for node 54...
            Jul-22 8:56:13 PM Z-Wave Z-Nyt HUSBZB-1: Restoring node information for node 53...
            Jul-22 8:56:13 PM Z-Wave Z-Nyt HUSBZB-1: Restoring node information for node 51...
            Jul-22 8:56:13 PM Z-Wave Z-Nyt HUSBZB-1: Restoring node information for node 49...
            Jul-22 8:56:13 PM Z-Wave Z-Nyt HUSBZB-1: Restoring node information for node 48...
            Jul-22 8:56:13 PM Z-Wave Z-Nyt HUSBZB-1: Restoring node information for node 47...
            Jul-22 8:56:12 PM Z-Wave Z-Nyt HUSBZB-1: Restoring node information for node 46...
            Jul-22 8:56:12 PM Z-Wave Z-Nyt HUSBZB-1: Restoring node information for node 45...
            Jul-22 8:56:12 PM Z-Wave Z-Nyt HUSBZB-1: Restoring node information for node 44...
            Jul-22 8:56:12 PM Z-Wave Z-Nyt HUSBZB-1: Restoring node information for node 43...
            Jul-22 8:56:12 PM Z-Wave Z-Nyt HUSBZB-1: Restoring node information for node 41...
            Jul-22 8:56:12 PM Z-Wave Z-Nyt HUSBZB-1: Restoring node information for node 40...
            Jul-22 8:56:12 PM Z-Wave Z-Nyt HUSBZB-1: Restoring node information for node 39...
            Jul-22 8:56:12 PM Z-Wave Z-Nyt HUSBZB-1: Restoring node information for node 38...
            Jul-22 8:56:11 PM Z-Wave Starting Z-Wave Polling for Network F9B23B15...
            Jul-22 8:56:11 PM Z-Wave Z-Nyt HUSBZB-1: Restoring node information for node 36...
            Jul-22 8:56:11 PM Z-Wave Z-Nyt HUSBZB-1: Restoring node information for node 35...
            Jul-22 8:56:11 PM Z-Wave Z-Nyt HUSBZB-1: Restoring node information for node 33...
            Jul-22 8:56:11 PM Z-Wave Z-Nyt HUSBZB-1: Restoring node information for node 31...
            Jul-22 8:56:11 PM Z-Wave Z-Nyt HUSBZB-1: Restoring node information for node 27...
            Jul-22 8:56:11 PM Z-Wave Z-Nyt HUSBZB-1: Restoring node information for node 26...
            Jul-22 8:56:11 PM Z-Wave Z-Nyt HUSBZB-1: Restoring node information for node 25...
            Jul-22 8:56:10 PM Z-Wave Z-Nyt HUSBZB-1: Restoring node information for node 24...
            Jul-22 8:56:10 PM Z-Wave Z-Nyt HUSBZB-1: Restoring node information for node 23...
            Jul-22 8:56:10 PM Z-Wave Z-Nyt HUSBZB-1: Restoring node information for node 22...
            Jul-22 8:56:10 PM Z-Wave Z-Nyt HUSBZB-1: Restoring node information for node 21...
            Jul-22 8:56:10 PM Z-Wave Z-Nyt HUSBZB-1: Restoring node information for node 20...
            Jul-22 8:56:10 PM Z-Wave Z-Nyt HUSBZB-1: Restoring node information for node 19...
            Jul-22 8:56:10 PM Z-Wave Z-Nyt HUSBZB-1: Restoring node information for node 18...
            Jul-22 8:56:10 PM Z-Wave Z-Nyt HUSBZB-1: Restoring node information for node 17...
            Jul-22 8:56:09 PM Z-Wave Z-Nyt HUSBZB-1: Restoring node information for node 16...
            Jul-22 8:56:09 PM Z-Wave Z-Nyt HUSBZB-1: Restoring node information for node 15...
            Jul-22 8:56:09 PM Z-Wave Z-Nyt HUSBZB-1: Restoring node information for node 14...
            Jul-22 8:56:09 PM Z-Wave Z-Nyt HUSBZB-1: Restoring node information for node 13...
            Jul-22 8:56:09 PM Z-Wave Z-Nyt HUSBZB-1: Restoring node information for node 12...
            Jul-22 8:56:09 PM Z-Wave Z-Nyt HUSBZB-1: Restoring node information for node 11...
            Jul-22 8:56:09 PM Z-Wave Z-Nyt HUSBZB-1: Restoring node information for node 10...
            Jul-22 8:56:08 PM Z-Wave Z-Nyt HUSBZB-1: Restoring node information for node 9...
            Jul-22 8:56:08 PM Z-Wave Z-Nyt HUSBZB-1: Restoring node information for node 8...
            Jul-22 8:56:08 PM Z-Wave Z-Nyt HUSBZB-1: Restoring node information for node 7...
            Jul-22 8:56:08 PM Z-Wave Z-Nyt HUSBZB-1: Restoring node information for node 6...
            Jul-22 8:56:08 PM Z-Wave Z-Nyt HUSBZB-1: Restoring node information for node 5...
            Jul-22 8:56:08 PM Z-Wave Z-Nyt HUSBZB-1: Restoring node information for node 4...
            Jul-22 8:56:08 PM Z-Wave Z-Nyt HUSBZB-1: Restoring node information for node 3...
            Jul-22 8:56:08 PM Z-Wave Z-Nyt HUSBZB-1: Restoring node information for node 2...
            Jul-22 8:56:07 PM Z-Wave Z-Nyt HUSBZB-1: Restoring node information for node 1...
            Jul-22 8:56:04 PM Z-Wave Security S2 Support Is Enabled
            Jul-22 8:56:04 PM Z-Wave Z-Nyt HUSBZB-1 has successfully been made the SIS for this network.
            Jul-22 8:56:04 PM Z-Wave Z-Nyt HUSBZB-1 attempting to set as SUC/SIS...
            Jul-22 8:56:04 PM Z-Wave Z-Nyt HUSBZB-1 is the Primary Controller for this network.
            Jul-22 8:56:04 PM Z-Wave Z-Nyt HUSBZB-1 Controller is static lib.
            Jul-22 8:56:04 PM Z-Wave Z-Nyt HUSBZB-1 Controller chip type is ZW050x.
            Jul-22 8:56:04 PM Z-Wave The interface's security support has been set.
            Jul-22 8:56:04 PM Z-Wave Z-Nyt HUSBZB-1: Found 1 Z-Wave nodes in interface node ID 1 (Z-Nyt HUSBZB-1)
            Jul-22 8:56:04 PM Z-Wave Z-Nyt HUSBZB-1: Z-Wave interface node ID: 1, Home ID: F9B23B15
            Jul-22 8:56:04 PM Z-Wave Z-Nyt HUSBZB-1: Z-Wave Serial API version: 5
            Jul-22 8:56:04 PM Z-Wave Z-Nyt HUSBZB-1: Controller firmware version: 4.32
            Jul-22 8:56:02 PM Z-Wave Z-Nyt HUSBZB-1: Getting node information from controller...
            Jul-22 8:55:56 PM Z-Wave Warning A Z-Wave interface on the system is being restarted - some Z-Wave signals could be missed.
            Jul-22 8:55:51 PM Z-Wave Z-Nyt HUSBZB-1: Erase complete - sending the network ID to the interface.
            Jul-22 8:55:51 PM Z-Wave Z-Nyt HUSBZB-1: Controller firmware version: 4.32
            Jul-22 8:55:47 PM Z-Wave Z-Wave Interface Z-Nyt HUSBZB-1 (1) has been reset to its defaults.
            Jul-22 8:55:47 PM Z-Wave Warning Z-Nyt HUSBZB-1: Erasing the interface...
            Jul-22 8:55:47 PM Z-Wave Z-Nyt HUSBZB-1: Restoring node information from the file /opt/HomeSeer/Data/Z-Wave/ZNet_timon.ZWave. Please wait...
              No problem with Z-Wave plugin version 3.0.1.252 either.
                Ok, so I've got 252 and performing a restore does NOT work - could be to do with my controller node is at address 108? I've got a UZB stick.
                So, it seems to do a reset, sets a temporary home ID, then never flashes the old home ID - any ideas on what to actually do?
                Jul-26 14:46:43 Z-Wave UZB: Z-Wave interface node ID: 1, Home ID: FDE852A9 - this is still the temporary new home ID....
                Jul-26 14:46:43 Z-Wave UZB: Z-Wave Serial API version: 5
                Jul-26 14:46:43 Z-Wave UZB: Controller firmware version: 5.2
                Jul-26 14:46:43 Z-Wave UZB: Controller Manufacturer: PowerLynx, ID=0x1, Type=0x4
                Jul-26 14:46:40 Z-Wave UZB: Getting node information from controller...
                Jul-26 14:46:40 Z-Wave UZB: ----------------------------------------------------------------------
                Jul-26 14:46:40 Z-Wave Initializing Z-Wave interface UZB (Z-Wave.me UZB) on COM3
                Jul-26 14:46:40 Z-Wave UZB: ============================================================ ==========
                Jul-26 14:46:33 Z-Wave UZB: Exiting COM Device Thread
                Jul-26 14:46:33 Z-Wave Warning A Z-Wave interface on the system is being restarted - some Z-Wave signals could be missed.
                Jul-26 14:46:28 Z-Wave UZB: Erase complete - sending the network ID to the interface.
                  Yep, that's what's happening. Are you using a real Z-Net or a RPi setup with the generic ser2net wither the standard one or zwolfpack's updated version? I'm currently on HS's version but will be trying zwolfpack's version soon. I'm currently running Z-Wave: 3.0.1.262 but I've tried 252 and 258.
