How to figure out what device this is?
  • How to figure out what device this is?
    Today I received the following error message: Click image for larger version
    Here is the Node Information:
    I have no idea how to figure out what Device Node 134 is? Any ideas?
    It looks like your Zwave system has a device that HS doesn't know about. You may have to do a mental audit of what switches/devices you have and cross reference which isn't showing in HS...
      That will be quite a process with 87 active Devices. Might be the only way though
        Its a multi-level sensor, that should help narrow it down.
          You can also use the Device page and look in the Location 2 dropdown for "Node 134".
            I did a search for 134 in the Log and found the device. I will now exclude it and then add it back in. Thanks
              If not too late, you might just Rescan it and see if that fixes the problem
                I excluded and then added it it back and all is well. Thanks
