How to know HS3 has restarted
  • How to know HS3 has restarted
    I'm working on some status messaging via email and HSTouch for a remote site.
    Couple of questions:
    How can I tell that HS3 has just restarted?
    1. What is the life of counters, timers and global variables in terms of a restart? Do they hold their value or reset? My initial testing seems to indicate they retain their value.
    2. Are there any replacement variables that contain:
      • CPU Usage
      • System Uptime
      • Memory usage
    Thanks.
    For restart, edit the scripts/startup.vb and send yourself an email. This will let you know it has started.
    Sent from my SM-G935U using Tapatalk
      Jon00 has some scripts that are very useful for the tasks you are thinking of.
      https://forums.homeseer.com/showthread.php?t=123313
      I'd recommend you consider his PerfMon script in particular.
      There is a scripting function, 'hs.SystemUpTime', that reports uptime, but I'm not aware of a replacement variable. There is a script, 'Startup.vb' that runs when the system starts. That will give you an opportunity to run an event to carry out tasks such as sending you an alert message, or start a timer that will keep track of how long the system has been run.
      HS3 Pro Edition 3.0.0.548
        To add onto what rmasonjr said: I have an event called "Boot" that waits about 20 seconds (for HS to finish starting up) then sends me a notification telling me HS started up successfully.
        To run the event at startup, I just added this line near the bottom of startup.vb
        hs.TriggerEvent ("Boot")
          bphillips,
          I can handle that. It makes sense and I prefer using events.
          Thanks!
            I have a line at the beginning of my startup.vb which I renamed to RAPstartup.vb so that new installs do not overwrite the script - it has happened.
            hs.triggerevent("Startup Occurred")
            ' This is the startup script
            ' It is run once when HomeSeer starts up
            ' You may also have Startup.vb and it will be run instead of this script.
            Sub Main(Parm As Object)
                hs.WriteLog("Startup", "(RAPStartup.vb script) Scripting is OK and is now running RAPStartup.vb")
            I also use a script at shutdown that takes care of some other tasks. it can be configured in setup under the Custom tab.
            Click image for larger version  Name:	image_58872.png Views:	1 Size:	6.4 KB ID:	1188541
            Within that event I take care of any housekeeping I need after boot up. It is easy to add actions, other events with conditions honored, timer controls, counter controls, etc. I send myself a Pushover message telling me HomeSeer restarted and at what time, restart an uptime counter, get my lights synchronized with the time of day, poll a couple of critical devices to make sure they didn't change state while HomeSeer was down, etc. It is a one stop repository for startup events.
            I ended up putting the delay in to give HomeSeer a chance to settle down before proceeding with cleanup.
            Click image for larger version  Name:	image_58873.png Views:	1 Size:	123.3 KB ID:	1188542
            Randy Prade
            Aurora, CO
            Prades.net
              @bphillips
              Just did this and it worked great. I like that it is an event that I can easily change.
              Thanks again.
