I am trying to keep a room cool in my house. I have a temp monitor in the room and have a zwave thermostat. I have setup an event that says
IF Room temp is above 78 degrees and the Harmony Hub is on then adjust the thermostat to 76 degrees. I want to then have the ROOM temp monitor continually check the temperature until it reaches 77 degrees then adjust the thermostat back to 78 degrees.
I idea is to turn our house AC on to cool this one room of the house but only do it when we are watching TV (Harmony hub) in that room and only when the temperature in that room is above 78 degrees. The biggest question is how do I have it monitor the temp and re adjust so it does not always do this when we have left the room or stopped watching TV.
Any help is greatly appreciated.
