Hello!
I'm migrating (slowwwwwly) from h2 to hs3.
I have a simple?? problem in creating a manual event, as apparently the HS3 does not respect the logic of the "If/Then"statement
The purpose of the event is, using Alexa's voice:
1. Turn on the security system (Security on event)
2. Verify that all ports and windows are closed (Check Integrity event)
3. If they are closed do nothing because the security system, when the timing is over will activate (Check Integrity event)
4. If any door or window is open, turn off the alarm system and notify by vocal synthesis (Check Integrity event)
The problem is that the actions of the "Check Integrity" event (Capture2) will ALWAYS run regardless of the status (ON / OFF) of the GTS CPUXA Secu16 Unit2 Integrity ....
If I delete the first constraint (the event is no longer triggered manually) the IF / Then logic starts to function as expected ....
The execution of a manually triggered event can't be conditional???
I'm missing something?
Can someone help?
Can someone help?
