Pass device string to external program?
    I run HS3 on Linux, and use shell scripts for things such as sending SMS messages. Currently I have an event that sends me an SMS if my freezer temperature is too high. It would be nice to include the actual temperature in the message. Is there a way to pass device strings or values on the command line to an external program? I can pass a static command line, but would be nice to include some device data in there.
    HS Pro 3.0 | Linux Ubuntu 16.04 x64 virtualized under Proxmox (KVM)
    Hardware: Z-NET - W800 Serial - Digi PortServer TS/8 and TS/16 serial to Ethernet - Insteon PLM - RFXCOM - X10 Wireless
    Plugins: HSTouch iOS and Android, RFXCOM, BlueIris, BLLock, BLDSC, BLRF, Insteon PLM (MNSandler), Device History, Ecobee, BLRing, Kodi, UltraWeatherWU3
    Second home: Zee S2 with Z-Wave, CT101 Z-Wave Thermostat, Aeotec Z-Wave microswitches, HSM200 occupancy sensor, Ecolink Z-Wave door sensors, STI Driveway Monitor interfaced to Zee S2 GPIO pins.
    There must be an easier way, but the only way I can think of is to write the string to a file, then read the file in the external event. Is that an option?
      Thanks Mike. I may just end up writing a C# script to handle SMS which could look up the values, or adding code to my current PHP script to talk to the HS JSON API.
        I did the latter, added code to my Perl scripts (to talk to the HS JSON API).
        Len
        HomeSeer Version: HS3 Pro Edition 3.0.0.435
        Linux version: Linux homeseer Ubuntu 16.04 x86_64
        Number of Devices: 633
        Number of Events: 773
        Enabled Plug-Ins
        2.0.54.0: BLBackup
        2.0.40.0: BLLAN
        3.0.0.48: EasyTrigger
        30.0.0.36: RFXCOM
        3.0.6.2: SDJ-Health
        3.0.0.87: weatherXML
        3.0.1.190: Z-Wave
