I have been following the discussion on the latest HS version and note that counter and timer devices can create a problem.
I have two events that use a counter value, testing if it is in a specified range. That is, it has to be greater than one value and less than another. As far as I can tell, there is no way to do that without using the corresponding device or a script. Is there an alternative that I am not aware of?
While exploring that question I realized that there is a counter condition that does not appear to make sense. Namely, 'And If [Counter] value becomes this'
This would appear to be a nearly useless condition because the counter becoming a specific value would have to be coincident with the trigger. Am I misunderstanding how this event condition works?
