I just bought a ZOOZ Z-Wave Plus 4-in-1 Sensor ZSE40 VER. 2.0 to monitor my boiler room for temp., humidity, lighting and motion.
Every if reporting properly except light levels but that is not my main concern.
I have events to send an email if the temp or humidity go above a certain level or below another level. I have time conditions set as well. But here is the issue:
I want the Homeseer to notify me if the temperature goes above 85 degrees but not notify me again until the temp goes back below 85 degrees.
It would be great if I could set an event to notify me if the temp. goes outside of a specific range and then again when it gets back within range. For example, temp between 50 and 85 all is good. Above 85 or below 50 I get an email. Then another email when it is back within range. Same for Humidity but 30-60%
Currently it is reporting on every change above 85. So I will get notified at 85.1 or above and then again at every change above that temp. I received 10 notifications last night between 10pm and 5am.
I read this post : https://forums.homeseer.com/showpost...94&postcount=8
I am not grasping how the virtual device works in this example.
Yes, that should work the same.
IF the humidity reports less than 30% the event will run. If the humidity reports greater than 70% the event will run. It will run every time the device reports within those values. It doesn't have to report a change in humidity either. If it last reported 77% and 5 minutes later it reports 77% the event will run again. As you suggested, one possibility is the Cannot Re-Run advanced option to limit the emails to once every XXh, XXm, XXs when the humidity reports outside the 30-70% range.
Another possibility is a virtual device that is set by the event and also used as conditions on both Triggers. A second event would turn the virtual device when the humidity is greater than 30% and less than 70%. This would have it send one email when the humidity is out of range the first time and not again until it has gotten within range then goes outside range again. IT just depends on how often you want to be notified.
