I want to create an event that tells me if the Z-Wave controller is not working correctly (some form of watchdog). I have Z-net. Can someone receommend how? I currently ping the z-net but this doesn't confirm the Z-Wave controller is actually fully functional.
Detect Z-Wave Controller Failure
Originally posted by BobSpen View PostI have an "extra" switch that I switch off then on, by a recurring event every 5 minutes. I have a second event that triggers an error message if that device ever goes "unknown" state.
Have you done any kind redundancy Z-wave? i.e if the Main controller fails, can a secondary controller take over..
In other words, how does one trigger on Status instead of Device value?
I mis-stated, the actual trigger, for my Leviton switch, is a "An Error or Invalid State" which is in the drop-down for that switch. There is also an "Unknown(Value)".
If something is like "Error....Invalid" is not on the drop-down for your device, look at he device page status-value pairs(Status Graphics tab) and see if there is a value assigned to "Error,,,Invalid".
You also could try removing power from the lock, then send a command and see what value is set in the HS device.
Also worth noting is there are two ways a device can become “Unknown”. One is if the status goes to Unknown and the other when hs.DeviceInvalidValue = True. The latter will not show in the Status/Value of the device, only in the PED for the device. The Error/Unknown trigger is by the PED data.
This thread may help.
Originally posted by rprade View PostAlso worth noting is there are two ways a device can become “Unknown”. One is if the status goes to Unknown and the other when hs.DeviceInvalidValue = True. The latter will not show in the Status/Value of the device, only in the PED for the device. The Error/Unknown trigger is by the PED data.
