Hi All
Apologies if this request has been asked previously, but just finding my feet and have recently start using and exploring HS3
I was wondering whether you can provide assistance with creating an event in HS3 to accomplish the following:
I’m installing a Fibaro zwave double switch to control my Air-conditioning on a split level home. (ground floor and second floor)
What I am trying to achieve is that I need at all time one switch always on the ‘On” positioning to avoid the A/C running and both levels closed.
The switches will be controlling a damper (A damper is a valve or plate that stops or regulates the flow of air inside a duct pipe)
Switch 1 will do the bottom level of my house and switch 2 will do the upstairs
Looking for assistance to create the above event to run in the back ground to ensure both switch are never in the OFF position
Pat
- If Switch 1 is On then Switch 2 can be off - OK
- If Switch 2 is ON then Switch 1 can be OFF - OK
- If both Switches 1 & 2 are OFF , then Switch 1 must be turned ON (both switch cannot be OFF) - this will protect the A/C from running and no air circulating, which can damage the A/C unit
Pat
