I have an event to set the heat point of a thermostat - but it only gives a dropdown with whole degrees in it.
Is it possible to change this through some configuration? Whole degrees (celcius) is too big a step for indoor temperatures.
The thermostat supports one decimal place, and this works fine when set from the HS3 home screen or through a script, but I want to be able to do it through the visual events interface.
