All,
With 100's of events and devices supervising all aspects of my household, I've run into a problem with a specific lamp (its primary hardware control = insteon lamp module. This device can become stuck in an endless on/off loop that cannot be shut off (stopped).
I've considered at length a most effective method of another event taking charge of this “out of sync situation,” and ending it. It’s very hard to stop a run-away event double without shutting off events within HS3.
The best trigger for this situation would be a sequence of this lamp being turned on, then off inside a set time period (let's use 3 seconds as a safe window).
I recognize that "bad programming" may be some users' immediate thoughts, although this is not the case here. One of the triggers that can initiate this runaway loop is an IR signal from a coffee table remote being corrupted before its reception by an X-10 receiver module. This is a random occurrence depending on sunlight, etc. in the room. The event typically works perfectly to turn the device on or off.
Any ideas how to shut off the (several) events related to this lamp module to allow resetting the lamp's insteon device and its insteon keypad button states? Sorry in advance for the length of this posting.
Peter
Peter
