I'm trying to copy a configuration from one SEL to a second unit. I'm doing it by backing up the configuration on the setup page, then restoring the configuration on the second unit. On the second unit, my events all show up without a trigger. Here's an example. This is making me crazy. I'm running out of ideas. Anybody else have a suggestion?
Problems copying events from one SEL to another - Solved!
Thanks. You are correct about the mono versions. In fact, I bought the second unit in part because when I attempted a mono upgrade, it was a disaster. So I bought a second unit that already had mono 5 installed. Once I get it up and running, I can mess with trying to upgrade the old one. Anyway, I tried your suggestion, and it worked. Thank you so much!
