Simple event, light on between sunset and sunrise, how?
  • #16
    Originally posted by RoChess View Post
    rprade those gardenlights for lack of better term, do you got any links on those?
    I've driven past the driveway a few times during heavy rain or when not paying attention, so I jokingly thought I should add lights along the way and upon location proximity detection fire off a HS3 event that makes them glow towards the house like a landing strip.
    Your video is extremely close to that idea with the lights on the left side.
    Ohio winters can be brutal, so I might need to account for a few feet of snow.
    They are Orbit 120v 4 tier fixtures, available in green or black as far as I know. The 4 tier were the only ones that put the sweet spot of a Hue A19 low enough to look good. The three tier puts the bulb up in the canopy. We wanted colors to be rich and bright. My wife liked the looks of them as well. They are well-made, all metal with glass lenses and gasketed. They come with an 8" riser, but I think it is 1/2" threaded. You can contact them about longer risers. These things are holding up well, though the screws are rusting a little.
    Click image for larger version  Name:	green.png Views:	0 Size:	141.2 KB ID:	1326340
    Click image for larger version  Name:	black.png Views:	0 Size:	53.9 KB ID:	1326341
    I got mine from USA Lighting here
    I mounted mine with PVC ground spikes and ran 14-2 UF cable between them.
    Click image for larger version  Name:	spike1.png Views:	0 Size:	52.2 KB ID:	1326342
    Click image for larger version  Name:	spike2.png Views:	0 Size:	23.9 KB ID:	1326343
    Randy Prade
    Aurora, CO
    Prades.net
    • #17
      rprade those look awesome, and might look at that before winter hits. Colorado must get good snow as well, and those looked like Christmas videos, so how did you manage snow removal? Are they super sturdy, or did you first crank the Hue bulbs up to snow-melting intensity?
      The driveway here is about 50 feet from road, but that is why I like the idea of these 120V lights and the Hue lights should act as a Zigbee repeater. This also solves my problem of extending sensor range towards mailbox that I wanted to eventually add a sensor on.
      • #18
        They are sturdy units, never had one broken or knocked over.
        They are in the grass about 6” from the driveway. We get a lot of snow, though only a few major accumulations a season. 6-12” is not unusual, but we’ve seen 3 feet from time to time. On the rare occasions when they have been covered, I have some 3’ rods I stick in the snow to help guide me and the snow thrower. If I suspect a storm I will usually stick them in the ground the night before.
        Randy Prade
        Aurora, CO
        Prades.net
        • #19
          ' lightID is the light or group name
          dim lightID as string = "Porch Lights"
          'brightDev is the master brightness control
          dim brightDev as integer = 9170
          'transDev is the transition time device
          dim transDev as integer = 9952
          'colDev is the color selector device
          dim colDev as integer = 9172
          'specDev is the special level device
          dim specDev as integer = 9171
          sub Main(ByVal Parms as Object)
          if hs.DeviceValue(colDev) = 1 Then
          hs.PluginFunction("JowiHue", "", "SetLightsHueSat", {True, lightID, hs.DeviceValue(brightDev), 1, 255, hs.DeviceValue(transDev)})
          End If
          if hs.DeviceValue(colDev) = 2 Then
          hs.PluginFunction("JowiHue", "", "SetLightsHueSat", {True, lightID, hs.DeviceValue(brightDev), 10752, 255, hs.DeviceValue(transDev)})
          End If
          if hs.DeviceValue(colDev) = 3 Then
          hs.PluginFunction("JowiHue", "", "SetLightsHueSat", {True, lightID, hs.DeviceValue(brightDev), 26260, 255, hs.DeviceValue(transDev)})
          End If
          if hs.DeviceValue(colDev) = 4 Then
          hs.PluginFunction("JowiHue", "", "SetLightsHueSat", {True, lightID, hs.DeviceValue(brightDev), 42000, 255, hs.DeviceValue(transDev)})
          End If
          if hs.DeviceValue(colDev) = 5 Then
          hs.PluginFunction("JowiHue", "", "SetLightsHueSat", {True, lightID, hs.DeviceValue(brightDev), 46848, 255, hs.DeviceValue(transDev)})
          End If
          if hs.DeviceValue(colDev) = 6 Then
          hs.PluginFunction("JowiHue", "", "SetLightsHueSat", {True, lightID, hs.DeviceValue(brightDev), 53028, 255, hs.DeviceValue(transDev)})
          End If
          if hs.DeviceValue(colDev) = 7 Then
          hs.PluginFunction("JowiHue", "", "SetLightsHueSat", {True, lightID, hs.DeviceValue(brightDev), 4000, 255, hs.DeviceValue(transDev)})
          End If
          if hs.DeviceValue(colDev) = 8 Then
          hs.PluginFunction("JowiHue", "", "SetLightsKelvin", {True, lightID, hs.DeviceValue(brightDev), "6000" ,hs.DeviceValue(transDev)})
          End If
          if hs.DeviceValue(colDev) = 9 Then
          hs.PluginFunction("JowiHue", "", "SetLightsKelvin", {True, lightID, hs.DeviceValue(brightDev), "3000" ,hs.DeviceValue(transDev)})
          End If
          End Sub
          Just a suggestion - you could simplify your code a little as follows:
           select case hs.DeviceValue(colDev)
            case 1
            case 2
            case 3
            case 4
            case 5
            case 6
            case 7
            case 8
            case 9
           end select
          End Sub
          • #20
            Thanks, I’ll clean it up. That is a script I use for a lot of different Hue lighting. I am using all hue bulbs, so I could also probably pass the 4 devices as parameters, so that the same script could be used for all lights. I’m not a programmer, so I cobbled something together that worked, then edit the script’s device RefIDs and whether it is referencing a light or a group for the different lights or groups.
            Randy Prade
            Aurora, CO
            Prades.net
            • #21
              Randy,
              This might help you as a starting point.
                'Script to set Hue Lights
                  'Parms =
                  '1 = String lightID is the light or group name
                  '2 = Int brightDev is the master brightness control
                  '3 = Int transDev is the transition time device
                  '4 = Int colDev is the color selector device
                  '5 = Int specDev is the special level device
                  'Eg. ("Porch Lights",9170,9952,9172,9171)
                  'HueSat is the Sat Value to set
                  Dim HueSat As Integer = 0
                  'HueKelvin is the Kelvin Value to set
                  Dim HueKelvin As String = Nothing
                      Dim SplitParam() As String = Split(Parms, ",")
                      Dim lightID As String = SplitParam(1)
                      Dim brightDev As Integer = SplitParam(2)
                      Dim transDev As Integer = SplitParam(3)
                      Dim colDev As Integer = SplitParam(4)
                      Dim specDev As Integer = SplitParam(5)
                      Select Case hs.DeviceValue(colDev)
                          Case 1
                              HueSat = 2
                          Case 2
                              HueSat = 10752
                          Case 3
                              HueSat = 26260
                          Case 4
                              HueSat = 42000
                          Case 5
                              HueSat = 46848
                          Case 6
                              HueSat = 53028
                          Case 7
                              HueSat = 4000
                          Case 8
                              HueKelvin = "6000"
                          Case 9
                              HueKelvin = "3000"
                      End Select
                      If HueSat > 0 Then
                          hs.PluginFunction("JowiHue", "", "SetLightsHueSat", {True, lightID, hs.DeviceValue(brightDev), HueSat, 255, hs.DeviceValue(transDev)})
                      Else
                          hs.PluginFunction("JowiHue", "", "SetLightsKelvin", {True, lightID, hs.DeviceValue(brightDev), HueKelvin, hs.DeviceValue(transDev)})
                      End If
                  End Sub
              Greig.
              Scripts =
              Various
              • #22
                Thanks Greig;
                That makes sense and adds more to my scripting understanding. I will employ those changes as well.
                One last thing to hand off as a parameter determines if it is addressing a light or a group.
                For a group:
                For a Light:
                hs.PluginFunction("JowiHue", "", "SetLightsHueSat", {False, lightID, hs.DeviceValue(brightDev), HueSat, 255, hs.DeviceValue(transDev)})
                Randy Prade
                Aurora, CO
                Prades.net
                • #23
                  Thanks Greig;
                  For a group:
                  For a Light:
                  Randy,
                  Glad I can help you for a change and not the other way round!
                  I have added the Boolean and named it IsGroup but I am not sure if it should be called IsLight as I don't know which way round it works.
                  I also removed your specDev param as it is not used in the script, If you need it and want it to do something drop me an email.
                      'Parms =
                      '1 = Bool Is a lighting Group
                      '2 = String lightID is the light or group name
                      '3 = Int brightDev is the master brightness control
                      '4 = Int transDev is the transition time device
                      '5 = Int colDev is the color selector device
                      'Eg. (False,"Porch Lights",9170,9952,9172)
                          Dim IsGroup As Boolean = Parms(1)
                          Dim lightID As String = Parms(2)
                          Dim brightDev As Integer = Parms(3)
                          Dim transDev As Integer = Parms(4)
                          Dim colDev As Integer = Parms(5)
                              Case 1
                                  HueSat = 2
                              Case 2
                                  HueSat = 10752
                              Case 3
                                  HueSat = 26260
                              Case 4
                                  HueSat = 42000
                              Case 5
                                  HueSat = 46848
                              Case 6
                                  HueSat = 53028
                              Case 7
                                  HueSat = 4000
                              Case 8
                                  HueKelvin = "6000"
                              Case 9
                                  HueKelvin = "3000"
                          End Select
                          If HueSat > 0 Then
                              hs.PluginFunction("JowiHue", "", "SetLightsHueSat", {IsGroup, lightID, hs.DeviceValue(brightDev), HueSat, 255, hs.DeviceValue(transDev)})
                          Else
                              hs.PluginFunction("JowiHue", "", "SetLightsKelvin", {IsGroup, lightID, hs.DeviceValue(brightDev), HueKelvin, hs.DeviceValue(transDev)})
                          End If
                      End Sub
                  Greig.
                  Scripts =
                  Various
                  • #24
                    Originally posted by enigmatheatre View Post
                    Randy,
                    Greig.
                    Thanks again for the help. It is actually Group = True, Light = False, so it looks like you got it right. specDev is from an earlier iteration, I don't think I use it in any of the scripts. I think that does it. I will work on it later tonight.
                    Randy Prade
                    Aurora, CO
                    Prades.net
