Winter is coming and the sun is going to be up later. I'd like to set the bedroom lights to gradually brighten over a period of time. What's the best way to have this set up? Say start at 10% and gradually brighten to 100% over 15-30 minutes.
How to set gradual brighten "wake up lights"?
I have good news and bad news. The bad news is that there ought to be several ways to do this easily, but most of them I have not been able to make work. The good news is that the following approach (assuming you have EasyTrigger) will work:
Assume your bedroom light is off. You start the lighting process by triggering an event something like this (substituting your bedroom light device for what I call Office Ceiling Lights):
When your bedroom light comes on at the dim level, it will trigger an event that looks like this:
Here you are starting at a dim level of 10%. The brightening event increments brightness by 1% at 20 second intervals, so you should get to full brightness in about a half-hour. You can play with the trigger rate to change the brightening rate.
I don't know why the drop down list stops at 98%, but it doesn't really matter.
I ran into major difficulty when I tried to implement the IF condition as a change in the detected device value. So I'm unhappy to have unresolved issues, but what I offered above will work.
- 1 like
Originally posted by dannieboiz View PostWinter is coming and the sun is going to be up later. I'd like to set the bedroom lights to gradually brighten over a period of time. What's the best way to have this set up? Say start at 10% and gradually brighten to 100% over 15-30 minutes.
Insteon lights can do this natively. Brighten over 9 minutes is one of the ramp up options and have used it in the past.
Otherwise, you will have to create multiple events over desired time. I suppose you could even do a recurring event over a period of time.
What lighting system do you have?
If you don't have the EasyTrigger plugin, you can do so with scripting too: https://forums.homeseer.com/forum/ho...hten-over-timeHS 3.0.0.548: 1990 Devices 1172 Events
A script could also do what is needed. You could write one which accepts passed parameters such as the unit to change, a start and end level (0 and 100% or even 25 to 75%) and then a time. Of course, if it is always the same device and the time and ramp rate are the same, then you could hard code all of that to make it easier. S=Would be something like:
Code:Sub Main(Parm As Object) Dim DevRef As Integer Dim rampDelay As Integer Dim rampLevel As Integer Dim currLevel As Integer DevRef = hs.GetDeviceRefByName("Fireplace Inside Lights") rampDelay = 30 rampLevel = 20 currLevel = 0 Do currLevel = currLevel + rampLevel hs.CAPIControlHandler(hs.CAPIGetSingleControl(DevRef,false,currLevel ,false,true)) hs.WaitSecs(rampDelay) Loop Until currLevel > (99 - rampLevel) hs.CAPIControlHandler(hs.CAPIGetSingleControl(DevRef,false,"On" ,false,true)) End Sub
Karl S
HS4Pro on Windows 10
242 Devices
56 Z-Wave Nodes
37 Events
Google Home: 3 Mini units 1 display
As a further refinement of ericg's suggestion in post #2, you might also include a mechanism that will override the dimming effect if the light switch is manually operated.
One way to do it:
Set up a "virtual device" - i.e., a simple on/off switch. Include it as an "and" in the "Office Slowly Brighten" conditions. If off, then don't run the dimming effect. If on, then the dimming effect event can be run.
At the start of your event, i.e., in the "Office Set Dim" event, turn the switch "On"
Have another event whereby, if the Central Scene device associated with your light switch is changed (indicating someone manually touched the switch) turn the virtual switch "off" which then overrides / stops your dimming effect event.
See this thread for a script which uses passed parameters to do what you are asking if you are interested in that option.
Karl S
242 Devices
56 Z-Wave Nodes
37 Events
So here's what I discovered, all of my Linear and Zooz wall switches shows up. Hell even my Zwave locks show up but none of my light module mainly gocontrol this is a pretty generic module, schlage and some other company rebadge them. This is a big blow if I can't make it work cause testing it on what's available allows it to work really nicely.
Set the initial rampLevel to a value less than 100 to get them to ramp up and the rampDelay to a value in seconds for the time between each change in brightness. I had rampLevel at 20 and rampDelay at 30 so they came on at 20%, it waited 30 seconds and added another 20%, looping in this until it reached a point higher than 98 minus the ramp level. The it exits the loop and sets the device to On for a full brightness. My units would not accept a value of 99 or higher so they stopped at 80% Your modification will set it at 1% then 30 seconds later bring it up bright. 1% may not show any light.
I also linked an older post with what is probably a better script by, I believe sparkman, which takes input.Karl S
242 Devices
56 Z-Wave Nodes
37 Events
