I am setting up an event that will turn on the lights, inside the house, if the garage door is opened. I have the event set up to dim the lights after 5 minutes, then after that turn the lights off. I want to be able to cancel the event for the device if it is manually trigger.
If my wife walks inside the house and the lights are on, they dim after 5 minutes and then she turns them back on all the way, it will not turn them off.
My current setup is like this:
Also would there be a way to still shut off 2 or 3 lights if just the one light was manually enabled?
I believe I need to set up virtual devices to make this work but maybe not.
Nick
Nick
