Run event only if HS200 Fan device value is 2 or greater
    I have a HS 200+ Fan controller and would like to create an event that would set it's value to 1 only if it is on and value is 2 or greater. The event pictured that I created does this but also turns on the fan if it is off which I do not want to happen.
    Any help appreciated.
    Add a condition of the fan switch being greater than off.
      Thanks that should work but if the fan is off it still turns on to level one when I run it manually
      I must be missing something
        What happens if you reverse those two?
          Your first screenshot is correct...you don't need the condition in the second screenshot if you leave the trigger as in the first screenshot.
          I think the issue you are running into is that conditions are ignored when you run events by manually clicking the run button. Yes, its unintuitive and unfortunate, but that's how Homeeer rolls so we must deal with it. See here:
          https://forums.homeseer.com/forum/ho...event?t=174310
