I have several Insteon dimmers that were controlling live Halogen bulb loads - dimming was, of course, done by the electronics in the dimmer itself. Now, all of these halogen bulbs have been replaced with Fibaro and Qubino RBGW LED Z-Wave dimmers.
I can easily make an event that does "on dimmer set to on" then "set RBGW white to on"; or "on dimmer set to off" then "set RBGW white to off".
However, I can't see a way to pass the dimmer value to the device to be controlled in an event (I'm probably missing something obvious) so, for example, the event would read "on dimmer set to x%" then "set RBGW white to x%". How can I do this?
Thanks in advance.
Thanks in advance.
