Run event when the time equals a device value or string
    I need to trigger an event when the time is equal to a device's value.
    Specifically, I want to set a virtual device's value to a time such as 2300(hhmm). When the time is equal to the value of the device, I want to trigger an event.
    I set the value of the device in HSTouch. I could also use, I believe, the device's string value.
    The event would start a water sprinkler zone based on a time that can be changed from HSTouch.
    One way to do this would be to use a recurring event that sets a (new) device value to the current time in the same format as your current watering time device. Then use EasyTrigger to trigger an event when the two device values become equal.
      Years ago I was trying to do the same thing for a bedside alarm clock. I was hoping it would be as easy as to use the EasyTrigger String compare, but I couldn't get that to work for me. My solution was to do as Michael said about checking the time every minute. I put the current time into a virtual device to compare to my alarm time then ran the comparison script.
      Click image for larger version  Name:	Screen Shot 2019-12-10 at 11.32.30 AM.png Views:	0 Size:	106.8 KB ID:	1345745
      I have some other logic assembling the alarm time into the desired format, but my solution to compare the values was with a script.
      Click image for larger version  Name:	Screen Shot 2019-12-10 at 11.33.23 AM.png Views:	0 Size:	294.2 KB ID:	1345746
      Finally, here are the devices. You can see 377 and 379 down at the bottom. If they match, it turns 380 On which triggers my alarm.
        Here is the outline of a script that would be called on the days needed at midnight. It would check every 60 seconds to see if it should activate the zone. After activation it would exit. The event to water would be manually triggered.
        You will need to create global variable in startup.vb to store the HSTouch settings.
        An outline script is given below to get you started. You could pass parameters if you want.
        'Trigger a zone
        Sub Main()
        Dim ZoneTime As Time = hs.GetVar("zntime") 'get the time set by hstouch
        Dim CurrentTime As DateTime
        'You need to add the current date to the time to get a datetime for your hstouch time. <-------------------------------------
        Do While Minute < 1438 'allow for some time creep
        CurrentTime = Time 'Set the current time
        If (ZoneTime - CurrentTime).TotalSeconds < 59 then
        hs.TriggerEvent "WaterZone" 'Activate your watering device or event here
        Exit Sub 'Exit after it is run
        End If
        Minute = Minute + 1
        hs.WaitSecs(60)
        Loop
        End Sub
          Here is my startup.vb to declare and initialize global variables. It is .vb on my system but have to rename to .txt to upload.
          Startup.txt
            Many thanks to everyone's responses. I will try each of the methods provided to me. Your help is really appreciated.
              This is exactly what im working on right now - thanx!
              However, Im stuck on how you combine the values from 374, 375 and 376 into your device 377?
                I have an event that runs whenever any of the values change:
Name:	Screen Shot 2021-07-28 at 7.35.29 PM.png
                And here is the logic inside "Alarm_Time_Load.vb": ( I did not use a picture, maybe you can copy/paste and save some time.
                Sub Main(parm as object)
                Dim Chh as String
                Dim Cmm as String
                Dim Campm as Integer
                Chh=hs.DeviceValue(374)
                Cmm=hs.DeviceValue(375)
                Campm=hs.DeviceValue(376)
                if Campm=0 then
                if Cmm<10 then
                hs.SetDeviceString(377, Chh & ":0" & Cmm & " AM", True)
                else
                hs.SetDeviceString(377, Chh & ":" & Cmm & " AM", True)
                End If
                else
                if Cmm<10 then
                hs.SetDeviceString(377, Chh & ":0" & Cmm & " PM", True)
                else
                hs.SetDeviceString(377, Chh & ":" & Cmm & " PM", True)
                End If
                End If
                As always there is probably a better or at least many different ways to do this. This is just the first way I got it to work.
