Here is all I am trying to do:
I have a PIR and Inductive vehicle sensor on my driveway connected to Insteon I/O modules.
I have 4 coach lights over the garage doors.
When the Inductive or PIR senses movement on the driveway and it is between sunset and sunrise (night time) turn on the coach lights if for 15 minutes.
If no further motion, turn off the lights.
If more movement, keep resetting the 15 minute timer until the motion subsides, then turn the driveway coach lights off.
If it is after sunrise and before sunset (daytime) and there is motion do not turn on the lights.
My attempt attached below but lights were coming on during the day. If I can just see an example it sure it would get me going.
There are several more motion activated timed events I need to create and I am sure if I I can have one example to work from Iβll be fine with the rest.
Help!
Thanks.
Help!
Thanks.
