I have an EasyTrigger condition that will calculate what a three day average temperature is based on weatherxml foretasted temps and then set a virtual device to Heat/Cool/Off based on what that calculated value is. My question is, while I'm testing these events I would like to see what the calculated value is, so rather than creating another virtual device just to hold the calculated value, is there a way to maybe have the value stored in the device string and then send the device string value in a pushover?
How to send a calculated value via Pushover
Plugin's:
weatherXML, Jon00 Alexa Helper, Network Monitor, MyQ, Z-Wave 3.0.1.252Tags: None
Originally posted by will40 View PostI send device strings using pushover all the time using Homeseer replacement variables in the pushover message body for an example: $$DTR:126: & $$DTR:127:
I send strings from two different devices.HS3 3.0.0.548 &HSTouch Designer 3.0.71 with 996 Devices, 547 Events
Plugin's:
Originally posted by teladog01 View PostSomething like this maybe?
Code:&hs.SetDeviceString(AvgTempDevRef, CStr((hs.DeviceValue(Day1DevRef) + hs.DeviceValue(Day2DevRef) + hs.DeviceValue(Day3DevRef)) / 3), False)
Plugin's:
Originally posted by The Profit View PostThis script set the string of the virtual device but it also set the device value to the same calculated value.
SetDeviceString should not affect the device value, so something is fishy here. Deleting and recreating the virtual device would be a good thing to try. Or you could first try just recreating the value/status pairs (if you'd like to try to keep the device ref in place so you don't mess up events.)
So far the set of events has done a really good job of automating when to set the HVAC system to the appropriate mode. Next will be to incorporate open/closed door/windows.
Plugin's:
- 2 likes
