Events are not working....at all...
    Hi Everyone, my system has been up and running fine for months. As of a couple of days ago my events have stopped firing. If I kick them off manually, the steps within are not executed. This reminds me of about a year ago when I had to do a restore due to a bad SD drive, the events were visible, but not functional and I have to recreate them. Am I having the same issue?
    I have tried creating a test event and triggering it, it shows in the log as being triggered, but again no action is taken.
    Also the 'Last Ran' value does not get updated.
    HS3 ZEE S2 Edition 3.0.0.548
    -Don
    Couple of Questions that are not covered:
    1. Can you turn off the device via device management?
    2. Have you tried the different event with a different device.
    3. Have you checked z-wave connectivity?
    Sorry not much help but these are questions that come to mind. Maybe it will spark others to join in
      Have you tried replacing your database with a backup?
        Z-Wave communications is fine, I can control each device. Even Actions controlling Virtual Devices are not working.
        I am going to try restoring from a backup...
          Restoring the backup seems to have worked.
          Thank you!
