Can't Create New Events - Stuck on 'Loading'
    New issue today, wondered if anyone had ever seen it. HS3 3.0.0.548
    An event that used to work somehow got broken/corrupted and filled the logs with errors about an incomplete config. I tried to look at the event and all the actions were gone, and the web UI just showed 'loading'. I deleted the event. Now I can't create any new events without them too being stuck on 'loading'
    Click image for larger version  Name:	HS event issue.png Views:	0 Size:	12.9 KB ID:	1395115
    Strangely I think it had something to do with the BLOnkyo PI. I got an event log error about that after a few mins - I killed that and this error went from loading to "Exception rendering Action Row: Index was out of range. Must be non-negative and less than the size of the collection. Parameter name: index"
    The original event was related to BLOnkyo. Weird. Time to post in that forum if I can't figure this out.
    First thing to try is restarting HS. That will sometimes fix a database issue.
