I have a couple of unseen, untouched devices. One of them controls my hot water recirc pump. The device bit the dust and I didn't notice right away. Actually there were some unusual symptoms that I basically ignored for a few days. My bad.
The question is, "Is there a way to have an event notice that a particular device is switched on or off and is not reacting properly? This particular device switched on as it should have but then didn't switch off. Resetting it, it went to off but the next time it went to on, it stayed on.
I could create a timer to check how long it's been on but I assume the event would fail because HS thinks the command was sent, however it was never executed.
Is this something for a script that I am incapable of?
