HS-WS100+ IF Dim < %5 Turn Light OFF, but set Last Known Level to 30%
    My wife always dims the light down to the lowest setting, so Scene 001, which is a single top to the top paddle turns it to 1%. I made an even that would turn the switch off if it was below 5%, but of course the last known is still 1% due to her dimming.
    Is there a way to modify the Last Dim Value?
    I created a double tap even to just let her continue to do it her way, but allow me to use a double tap to bring it to 30%, but if the "DIM to OFF" triggers, the double tap triggers a Scene 001 which goes to 1% then turns off again. And a second double tap jumps to 30% so there is a weird malfunction.
    Instead of that double tap scene, just adjust the last known level to 30% on the DIM to OFF event. If I cannot modify the last value on the switch, then figure out the weirdness of the first double tap going to 1% then off and needing a second double tap.
