I have experienced event looping with the event in the screen capture below. I have also experienced the creation of over 9,000 events and delayed events.
It is the same issue as described here: https://forums.homeseer.com/forum/ho...nts-on-restart
After changing the rule to the screen capture below, it seems to be stable without any issues...until maybe after rebooting...(Have not attempted this as of yet).
I have also noticed that while there is an 'Ungrouped Events' present, it takes much longer to load user-created events (most likely because there are so many ungrouped events). This can also happen simultaneously with an ongoing/looping event (as can be seen within the screen capture below regarding the 1st screen capture above).
I have restored older event backups as well as deleting all events to stop the rogue events and then rebooted a few times. This has been a workaround to stop these events from getting out of hand although it still takes a long time for HomeSeer to attempt loading these 'Ungrouped & Delayed' events if they are still / become active.
Seems like this request may be necessary to keep delayed events stable: https://forums.homeseer.com/forum/ul...-device-action
As for infinite looping events, I am unsure of the cause...
