Event Trigger Not Executing Command
    Within the past week, a single event "Sunrise" with 4 actions fails to execute the first 3 actions. I deleted the event and recreated with a new name, "Sunrise2" but the same behavior. At 25 min past sunrise, the event should turn off three lights (the first 3 actions) and then 5 hours later, turn on a water fountain. The water fountain will turn on 5 hours later, but the first three actions do not execute.
    The log shows the event triggering, but the device action does not execute. See attached at 5/31/2021 5:36;06 am. All devices are Insteon modules.
    Posting a screen shot of the event might help.
    This could also be an Insteon issue, so posting a link to the problem on that forum might get a more Insteon-focused response.
    If you manually trigger the event from the event run icon do all the actions execute as expected?
      Thanks for the response. I'll post the screen shot when I return home this evening. All other events execute properly. But, to answer your last question, no, if I trigger the event manually, the event does NOT execute. But if I go to the individual device control, I can manually turn on/off.
        Event screen shot
          The way you have the event action configured, with multiple devices being controlled in a single event action, I would expect all four of the device actions to execute at the same time, 5 hrs and 25 mins after sunrise. If you want the first three devices to be controlled immediately, they should be moved to a separate event action without the 5 hour delay.
            I agree. I've also found that combining multiple devices in a single device action has not been totally reliable. I make it a practice to use a separate 'Then' for every action.
            See this thread for a bit more.
              I agree with the best practice of using a separate action for each device control. While a robust and stable system can send several device control actions at once, I have seen problems on slower systems, especially when controlling Z-Wave devices.
              Also, when multiple devices are controlled within a single action, the delay will apply to all devices. So all four of the devices will have the 5 hour delay.
                I don't understand this. Have we lost the ability to say:
                Do this
                Do that
                Do the other
                wait 20 minutes
                Do the last thing
                If so, why on earth?
                Enabled Plug-Ins
                3.0.0.6: AK Smart Device 3.0.1.9: AmbientWeather 2.0.63.0: BLBackup 3.0.55.0: BLGData 3.0.38.0: BLLock 2.0.26.0: BLUPS 3.2.0.1: Device History 3.0.0.73: EasyTrigger 3.25.614.1: HSBuddy 3.1.0.22: MeiHarmonyHub 3.1.0.2: SDJ-Health 19.10.7.1: TPLinkSmartHome 3.0.6681.34300: UltraCID3 3.0.6644.26753: UltraLog3 3.0.6554.33094: UltraMon3 3.0.5960.36744: UltraSighthoundVideo3 3.0.7806.23606: UltraWeatherWU3 3.0.2.0: Z-Wave
                  Do this
                  Do that
                  Do the other
                  wait 20 minutes
                  Do the last thing
                  You can still do that. I see the difference of what the OP's event does was:
                  Do this, that, the other, the last thing after waiting 20 minutes
                  Rather than:
                  Do this, that, the last thing
                  Do the other after waiting 20 minutes
                    Thanks everyone ... I just needed to slow down and read the event again. It is as several of you pointed out. I added the 5 hour delay of a new device (the fountain) and mistakenly added to the single event section. I have a few other events where I use a delay and knew that I had to separate into a different section, but I was sloppy and tried to add to the same section. Homeseer is operating as expected. Thus, the revised event ...
                    Thanks again.
                      Originally posted by dmusel View Post
                      <snip> I added the 5 hour delay of a new device (the fountain) and mistakenly added to the single event section. I have a few other events where I use a delay and knew that I had to separate into a different section, but I was sloppy and tried to add to the same section. Homeseer is operating as expected. Thus, the revised event ...
                      Thanks again.
                      I certainly didn't see this at first.
                      To somebody still on HS3, graphically, this is pretty cryptic, at first. I wish the HS4 documentation contained:
                      • more "examples," (i. e., a thing characteristic of its kind or illustrating a general rule [think: screen shot]) rather than another textual description of the text you already didn't understand and
                      • fewer blank pages (not 404, just blank).
                      Glad you figured out your problem and also glad this created a dialog that taught us something.
                      Enabled Plug-Ins
