Originally posted by Stevemeck
View Post
Constructing a series of events for motion controlled lighting
Hi Randy,
I've done that. Here is a cut of the additional Log info:
Jan-18 20:05:21 Event Event Trigger "Bedroom Reset timer"
Jan-18 20:05:16 Z-Wave Setting device Power to value 1.7
Jan-18 20:05:16 Z-Wave Set_New_Level, Parent: Upstairs Bedroom Bedroom Main, Child:Upstairs Bedroom Power
Jan-18 20:05:16 Z-Wave Set_New_Level_Real called for Upstairs Bedroom Power, Type=COMMAND_CLASS_SENSOR_MULTILEVEL_V7, EndPoint=-1
Jan-18 20:05:16 Z-Wave Set_New_Level_Real: Initial device is Upstairs Bedroom Power
Jan-18 20:05:16 Z-Wave ApplicationCommandHandler from node 14 HANDLING: COMMAND_CLASS_SENSOR_MULTILEVEL_V7 Frame(7)=5
Jan-18 20:05:15 Z-Wave Setting device Bedroom Main to value 0
Jan-18 20:05:15 Z-Wave Set_New_Level, Parent: Upstairs Bedroom Bedroom Main, Child:Upstairs Bedroom Bedroom Main
Jan-18 20:05:15 Z-Wave Set_New_Level_Real called for Upstairs Bedroom Bedroom Main, Type=COMMAND_CLASS_SWITCH_MULTILEVEL_V3, EndPoint=0
Jan-18 20:05:15 Z-Wave Set_New_Level_Real: Initial device is Upstairs Bedroom Bedroom Main
Jan-18 20:05:15 Z-Wave ApplicationCommandHandler from node 14 HANDLING: COMMAND_CLASS_SWITCH_MULTILEVEL_V3 Frame(7)=3
Jan-18 20:05:15 Z-Wave ApplicationCommandHandler from node 14 HANDLING: COMMAND_CLASS_SWITCH_MULTILEVEL_V3 Frame(7)=1
Jan-18 20:05:15 Z-Wave Handling CLASS_BASIC for Upstairs Bedroom Bedroom Main at Node 14, EndPoint=-1, Type=COMMAND_CLASS_BASIC_V2
Jan-18 20:05:15 Z-Wave Set_New_Level_Real called for Upstairs Bedroom Bedroom Main, Type=COMMAND_CLASS_BASIC_V2, EndPoint=-1
Jan-18 20:05:15 Event Event Trigger "Bedroom All off timer"
Jan-18 20:05:15 Z-Wave Device: Upstairs Bedroom Bedroom Main Set to OFF
Jan-18 20:05:15 Z-Wave Set_New_Level_Real called for Upstairs Bedroom Bedroom Main, Type=COMMAND_CLASS_SWITCH_MULTILEVEL_V3, EndPoint=1
A small update. I removed the unnecessary associations and left just Group 1 -> Homeseer.
This has reduced the number of re-curring triggers down to 2, so much better but still not working as I need 1 single trigger for each switch press.
I've tried the same 3 events with a different switch and I'm getting exactly the same behaviour. Here is a log of the kitchen switch. Is there something further I need to do with associations?
Ive also attached a screen shot of associations for completeness.
Thanks very much for your assistance so far Randy.
I have one room that is not acting as it should - The only difference is there are two sensors. There are 2 sensors - Ensuite Motion (works fine) and a shower sensor (this one does not).
In the past, this did work with the Fibaro HC2 but I think my logic might be wrong here. What is happening is the Multi 6 works perfectly however despite the Fibaro flashing, the light is still turning off. And once off, it flashes but does not turn on.
It's only when I stick my arm out over the shower door that the light turns on because the Multi 6 sensor detects motion.
As mentioned, on entry and even later, the Ensuite Motion is perfect. It's the Shower Motion Control that is not turning/keeping the light on.
Just to be clear, the status at the point of the light going off is :
Ensuite motion : Safe/no motion
Shower motion: Motion detected
I think it's more logic and as I type this, I am now thinking maybe I should change it to
When Ensuite sensor and shower sensor has been no motion for 2 minutes then start the turning off process as opposed to when then switch to no motion?
Thanks all
Motion = Light on
IF Upstairs Ensuite Motion Status changes and becomes On-Open-Motion
AND IF Upstairs Ensuite Shower Motion Control has a value equal to On
OR IF Upstairs Shower Motion Status changes and becomes Motion
THEN Remove Delayed Device Actions for : Upstairs Ensuite Shower Light
THEN Set Device Upstairs Ensuite Shower Light to On
No Motion = Light Off
IF Upstairs Ensuite Motion Status changes and becomes Off-Closed-No Motion
OR IF Upstairs Shower Motion Status changes and becomes No Motion
THEN Set Device Upstairs Ensuite Shower Light to Off
after a delay of 2 Minutes, 0 Seconds
Quite powerful. It gets us into the "automated home" rather than remote controlled home concept. Only thing is that it is quite a lot of work to enable all of the events, counters, and timers. One would think that this sort of a thing should get built into HS natively, or a plugin should be written.
Either way, thanks for sharing....HomeSeer 2, HomeSeer 3, Allonis myServer, Amazon Alexa Dots, ELK M1G, ISY 994i, HomeKit, BlueIris, and 6 "4k" Cameras using NVR, and integration between all of these systems. Home Automation since 1980.
Originally posted by aj84 View PostI have one room that is not acting as it should - The only difference is there are two sensors. There are 2 sensors - Ensuite Motion (works fine) and a shower sensor (this one does not).
Thanks all
Motion = Light on
I've attached an example of how I've used a delayed action for a motion controlled light. The only addition is that it has to be within a specific time schedule. (Using Spuds EasyTrigger plugin)
In my example, every time motion is detected the timer resets and delays the off command by that much time. You can adjust that based on your needs and depending on how your motion sensors work.HS3 3.0.0.548 &HSTouch Designer 3.0.71 with 996 Devices, 547 Events
Plugin's:
Originally posted by Krumpy View PostQuite powerful. It gets us into the "automated home" rather than remote controlled home concept. Only thing is that it is quite a lot of work to enable all of the events, counters, and timers. One would think that this sort of a thing should get built into HS natively, or a plugin should be written.
I personally like to have as much of my home and work space "Automated" rather than having to open up my phone or go to a tablet on a wall to turn on a light. I have that option at work and home but mostly for a situation that I either haven't figured out a way to automate yet or for that situation I haven't thought of yet that just came up.
I have to agree with you, it does take a lot of time to setup, I'm sure everyone here would agree with that. But for me, it's fun...and frustrating at times but the end result is kinda cool!HS3 3.0.0.548 &HSTouch Designer 3.0.71 with 996 Devices, 547 Events
Plugin's:
Not sure if you got sorted with your multiple triggers but only just saw your posts.
The Fibaro dimmer has a few caveats with HS3.
Assuming you have your associations sorted, then if you want to detect ON or OFF and only have your event fire once, change your trigger to "This device changes and becomes" then select ON or OFF. You should find that your event only fires once per value change.
This type of trigger means that the device has to change value for it to be fired, so if the device is at 99(ON) and you click once on the switch, the value will change from 99(ON) to 0(OFF). Regardless if the value is set to 0 multiple times, your event will only fire on the first value change.
This is a little more tricky if you want to fire on a value that is not ON or OFF (i.e. a dimmed value).
I'm sure you're aware that a double tap on S1 (assuming the default parameter settings) will set the connected load to 99(ON). A single tap (from OFF) will set to last value.
Lets assume that the light was at 50% then switched OFF.
The caveat is that a single tap from 0(OFF) will first cause the device value to go to 99(ON) before then changing again to 50 which could cause multiple event triggers depending on the trigger type used.
The way to deal with this is to use the "This device changes and becomes" trigger type and choose "a custom value or value range of" and use a range of 1 to 98.
Paul..
I'm having an issue with setting this up: if I have my light timer set to 5 minutes, and there is constant motion during that 5 minutes, the lights will turn off. The events don't get re-triggered because there is never a 'no motion' event sent (and therefore no 'motion' event sent to reset the timer). How is everybody else handling this?
Originally posted by MichaelD View PostWhen you 'Set Device [lamp] to On', do you then
'Remove Delayed Device Actions for: [lamp]'
then
'Set Device [lamp] to Off after a delay of mm,ss'
It looks like you might be missing the action to remove Delayed Device Actions'
I have been trying to get around to following the original 2015 post of how to do this motion control. I am new to HS. I now find that most of the latter half of the description, in particular the ON-OFF-ON signal and its control has disappeared from my view of the original post by rPrade. I am not sure whether this is a configuration thing or it has been changed or what. Can anyone help with this?
Originally posted by quinn View PostI have been trying to get around to following the original 2015 post of how to do this motion control. I am new to HS. I now find that most of the latter half of the description, in particular the ON-OFF-ON signal and its control has disappeared from my view of the original post by rPrade. I am not sure whether this is a configuration thing or it has been changed or what. Can anyone help with this?
