Thanks. I think this is quite an important thread for people trying to make HomeSeer do the essentials. I was using Vera/Pleg, but depending so heavily on an unofficial plug in did not seem to be a very secure boat. Sorry that it needs to be "reconstructed" as opposed to recovered..
Constructing a series of events for motion controlled lighting
Originally posted by quinn View PostThanks. I think this is quite an important thread for people trying to make HomeSeer do the essentials. I was using Vera/Pleg, but depending so heavily on an unofficial plug in did not seem to be a very secure boat. Sorry that it needs to be "reconstructed" as opposed to recovered..
I am trying to create a series of events, virtual devices, counters and timers that will allow me to suspend motion control of my garage lights. The main difference between my system and rprade is the fact that I am using a switch and motion control sensor within Lutron Radio RA2. With this system, the motion sensor communicates with the switch outside of HS3, thus, I cannot turn that communication off from within HS3. In addition, the motion sensors within RA2 are "dumb" in the sense that they only broadcast their status; you cannot change their status externally. I have also researched this on the Lutron forums, and Lutron does not support this type of functionality.
I was thinking of creating a series of events that would detect when the sensor reported no motion, and then immediately turn the light back on. The problem is that there is no way to distinguish when the lights are turned off manually versus when they are turned off by the motion detector.
Originally posted by rprade View PostI think I was able to reconstruct the second and third posts in the thread. Also note that I have replaced my Jasco switches with HomeSeer HS-WD100+, allowing me to replace ON-OFF-ON with central scene triggers.
Wondering if you might have some time and would mind updating either this thread or make a new one “Updated for HS Switches”? I’m sure your events have come a long ways since 2015! I’m thinking you probably don’t have some of those VD since EasyTrigger schedules....
Sent from my iPad using TapatalkHS3 3.0.0.548 &HSTouch Designer 3.0.71 with 996 Devices, 547 Events
Plugin's:
Originally posted by The Profit View Post
Hi Randy,
Originally posted by rprade View PostI just saw this post today. I will try to show the changes in some additional posts. I do use Easy Trigger schedules and HomeSeer Central Scene switches, but the underlying logic for motion control remains the same.
I haven't been able to get Tapatalk notifications working again so I just ran across your post by accident. Most everyone else has gotten it working so I'm thinking I'm just going to be left out in the cold on the issue so I'll keep checking back.HS3 3.0.0.548 &HSTouch Designer 3.0.71 with 996 Devices, 547 Events
Plugin's:
Here goes...
Since I initially posted the HomeSeer scene capable switches and dimmers became available as well as Spuds excellellent Easy Trigger plug-in. This provided much more flexibility and ease of configuration as compared to my original method using Jasco switches with counters and timers and a master motion control virtual device. Now, instead of a virtual device to determine when motion control was desired, I use an Easy Trigger schedule. I currently use three schedules, exterior, interior and basement. These schedules account for sunrise and sunset times. In addition, I have a "Low Light" virtual device that is controlled by the luminance sensor on my rooftop weather station. Here is one of the schedules
For each lighting group I use two virtual devices - Motion Master and Motion Enable. Motion Master is used to suspend motion control until it is specifically enabled again. Motion Enable is used for temporary suspension allowing the lights to remain off or on until they are manually controlled.
There are also some subtle changes to the Events. Here is the On by Motion Event:
There are two sections, scheduled and low light. Each is triggered by motion, require that the lights are off for at least 30 seconds (so that they will not trigger as I am leaving the room) and that the two virtual devices are on. If the Low Light Device is On, it will allow motion control outside of the schedule.
Here is the Off by No Motion Event:
The Off Event also has two sections. The first will cause the event to run if there has been no motion for at least 15 minutes, that the lights have been on for a few minutes and that motion control is enabled. The second section is a failsafe that will not let the lights stay on for more that 2 hours, unless there has been recent motion.
I have two Events for temporarily suspending and resuming motion control:
If the top or bottom paddle on the HS switch is held, motion control is temporarily disabled. This will leave the lights On or Off until manually controlled.
If the lights are turned on or off at the switch or set to off by event, the motion control is resumed. My "House to Sleep" routine turns all household lights off. Since the 3rd trigger is dependent on the lights being "Set" to off, this will restore motion control.
There are two Events allowing me to turn motion control Off or On on a persistent basis. These Events use Central Scene controls from the switch, instead of counters and timers with the Jasco switches. The old methods worked, but the Central Scene gives me much more control and easier Event construction.
- 2 likes
With dimmers, much is the same, except I use a set of level setting events that will set the dim level based on time of day, low light, etc. Each of the 6 default levels can be set through virtual devices.
When the lights are controlled it is through a level set Event. I call this level Event from the motion controls, or when controlling the lights from other Events.
This will set the lights to a level based on time of day or low light as well as being set to the last level if lighting defaults are not employed (controlled by the "Use Defaults" Virtual Device). Each of the called events will run based upon Easy Trigger schedule time of day and Virtual Devices. Here is for Night-Awake level:
If "Use Defaults" is Off, this Event runs
My master suspend and resume Events are the same as for switches. I only use a temporary suspend in the On position, since holding a paddle also will increase or decrease the level. To allow me to increase or decrease the light level, I added a pair of Events using the Central Scene double tap. Tapping the top twice turns the lights to On.
Tapping the bottom twice returns them to the default level.
- 2 likes
Hey rprade
Thank you for posting! I think just a couple of questions:
1) I don't understand the difference between "Motion Master" & "Motion Enable" virtual devices. Motion Enable is temporary and will automatically turn itself back on if any type of light control is made after Motion Enable was turned off, correct? Where Motion Master will allow user to control the light after Motion Master is turned off and won't turn motion back on unless it is three tapped? If the three tap isn't performed on the way out of the room, is there another event that you have that will automatically reset it back to On? I think you said that your good night event would reset the Motion Master....turning the light off does too, correct?
2) Do you have events for motion with Dimmers? I assume the tap and hold wouldn't work with dimmers?
3) If I remember correctly, a lot of your motion sensors are tied in with your security system, correct? I'm thinking about how the motion sensor (if not wired) settings would need to be set? My initial thought would be to set them so they trigger similar to wired, in that they reset to No Motion every 60 seconds?
Thanks Randy, really appreciate the amount of time you spend and detail that you put into your posts.HS3 3.0.0.548 &HSTouch Designer 3.0.71 with 996 Devices, 547 Events
Plugin's:
Motion Enable is turned back on whenever the top or bottom paddle is pressed, or if the switch is "set" to Off. My "House to Sleep" Event sets all lights to Off, so the Motion Enable devices are turned on each night when we go to bed.
