Monthly Low Battery Check
  • #76
    i'm trying to set this up again, an for all that is holy I can't seem to remember how to remove the txt extension???? and I must be the worst search person ever, as I can't find it online at all.
    please someone put me out of my misery.
    EDIT. Nevermind… finally found it.
    • #77
      Originally posted by jvm View Post
      I have an easy solution that works if you have the Easy Trigger Plugin.
      1. From the Easy Trigger plugin's "Config" screen, set up a dynamic Device Group called "Batteries" consisting of all devices there "Type" equals "Z-Wave Battery". If you have devices other than Z-Wave, you may need to modify this.
      2. Set up a simple event that triggers whenever a "Battery" device is set (i.e., at each battery report). The event just checks the battery level and sends an email if its too low. In the example below, I set that to 50%. Since most battery devices report their battery state about every 12-24 hours, this won't result in too many alerts. Also, I have it sent as a text to my phone (your cell phone provider typically has an address where you send an email and it converts into a text to your phone. Here, in the US, for ATT, that would be XXXXXXXXXX@mms.att.com where you replace XXXXXXXXXX with your phone #). Here's the event:
      Works GREAT! thanks. Just tried it with pushover
      • #78
        I also am having the same error of
        ERROR: Exception in script: Failed to compare two elements in the array.
        Current Date/Time: 17/09/2019 08:33:37
        HomeSeer Version: HS3 Standard Edition 3.0.0.500
        Linux version: Linux HS3-Closter 4.19.66-v7+ #1253 SMP Thu Aug 15 11:49:46 BST 2019 armv7l GNU/Linux System Uptime: 0 Days 7 Hours 13 Minutes 14 Seconds
        IP Address: 172.20.0.17
        Number of Devices: 179
        Number of Events: 39
        Available Threads: 399
        HSTouch Enabled: False
        Event Threads: 1
        Event Trigger Eval Queue: 0
        Device Exec Queue: 0
        HSTouch Event Queue: 0
        Email Send Queue: 0
        Enabled Plug-Ins
        1.3.7.3: Device History
        3.0.0.67: EasyTrigger
        0.0.0.45: Pushover 3P
        3.0.1.252: Z-Wave
        If anybody has success running this on linux?
        Devan
        • #79
          Is there easy way to modify the script to write the report in html file or any other file that I could display in HS Touch?
          Let say I would run the script once a day to update (overwrite) the report file.
          Thanks. Charles
          • #80
            I've been using this script without problems for a while now. But this weekend I added a Hue motion detector to my system and because it runs on battery I wanted to check that it was included in the report generated by the script. It was not...
            It looks like the reason is that Device Type = "Battery" (ONLY Battery) and because of this it is not recognized by the script. If I change the Device Type to something like "Test Battery" the device shows up in the report.
            Is there some way to change the script to fix this? I would avoid having to change the Device Type as this is easily forgotten when I add another Hue motion later...
