Run HS3 event from Vera using LUA
    Hello
    Is there anyway to run an event in HS3 using LUA code in vera
    i used to run HCL scenes from Vera but i can't figure out how to run HS3 events using the same way . this would help a lot with my Harmony activities .
    Rami
    You can enable json in the setup and then issue the following command to the web server:
    http://www.xxx.yyy.zzz/JSON?request=runevent&group=GROUPNAME&name=EVENTNAME
    Update with your ip and then the event details.
    Cheers
    Al
      Thanks Al
      I enabled JSON but it didn't work , do i have to add the port too ?
      Edited
      Working perfectly now from browser
      thanks a lot
        Is here anyway to do this from outside the house ? I have a static ip but how can I add the username and password to the http request ?
          Figured it out
          It should be
          http://user:password@IP:PORT/JSON?re...name=EVENTNAME
          This is amazing because I have these flic Bluetooth buttons and I have them around the house and in the car. You can run 3 actions ( click , double click and hold ) now working from the car or outside he wifi network
            Flic integration
            You definitely have a HomeSeer flic integration story to be told, rmohsen...
            For others: flic is an MHD ("must-have-device"), once having visited their web site at http://live.flic.io/ and the community at https://community.flic.io/
            /Per Hertz
