No rush, thank you
Trying to create a good night scene
The event engine in HS3 is extremely powerful and I'm sure everything you are wanting to accomplish can be done easily. If you could just explain concisely what it is you're after any number of us could explain how to do it.Originally posted by rpradeThere is no rhyme or reason to the anarchy a defective Z-Wave device can cause
Just programming a few more things, I noticed If I want to change some events, and add a event into the first 'then', I cannot add one, I have to change the first 'then', then change the seceond 'then' to what was the first and so on. I can add another 'then' at the end, but not move events (then) around. Or is that possible ?
Huh?
You can't add actions? I don't understand. You can add as many actions as you like. Also you can drag and drop the actions in any order you like. So if you have two actions and then you decide that you'd like a Wait between them you simply add a Wait action at the end and then drag it up in between the original two actions.Originally posted by rpradeThere is no rhyme or reason to the anarchy a defective Z-Wave device can cause
Originally posted by mikee123 View PostHm. I just tried dragging the actions but it doesnt work. Where do i have to click to drag and drop the actions ?Mike____________________________________________________________ __________________
Ok. I have a virtual switch with 4 states, which correspond to a setpoints I want to send to a thermostat. States are 14, 18, 20 and 21. So ideally I want this all in 1 event. So when I press 14, it sends 14, if I press 18, it sends 18 and so on. From what I understand so far I might have to split that in 4 events, as i cannot do:
if device is 14, then send 14, or if devise is 18, then send 18...
or can I do it somehow in 1 event ?
Originally posted by mikee123 View Postor can I do it somehow in 1 event ?
No. You need 4 events to accomplish this. What you're looking for is an Else and that doesn't exist and isn't really needed. There is only If, And If, Or If and Then.
I recommend you set aside some time to go through Randy's posts in the Event Clinic forum. There's a wealth of information there. All your questions will be answered and you will get great new ideas for things you never thought of doing.Originally posted by rpradeThere is no rhyme or reason to the anarchy a defective Z-Wave device can cause
There is Else functionality. As one of your actions you run another event that has its own conditions. You still need multiple events but you only have one event to trigger them. I use this functionality extensively.Originally posted by rpradeThere is no rhyme or reason to the anarchy a defective Z-Wave device can cause
