Hi all
i just have seen a bug ( if it is a bug ) or im doing something wrong
If i have an event like this :
The trigger event
IF Virtual Devices Server status changes and becomes Shutting down
Then If the Event Conditions are True, Run Event Power recovery mode manual
The event with condition (i disabled this event) :
Then Speak its ok
Then Execute the command: &hs.WriteLogEx("TEST","WORKING","#00a0ff")
DO NOT LOG THIS EVENT
So if i put my virtual to shutting down , it runs my event correctly , but no speech... but it says in the log ,its ok in blue
why doesn't it speak when i enable do not log this event?
The trigger event
Then Speak its ok
