Is there any way to check for an entry in the log file to act as the trigger for an event? I haven't stumbled across it searching through the forums or within the HS3 options/drop-downs, but thought I'd throw the question out to some of the HS3 Masters to see if anyone had a suggestion. In this example, I'd be looking to parse against a specific string that just appeared in the logs, then take an action based on that. Cheers, Matt
Trigger based on a log entry?
