My AC events are not firing, and I do not understand why. The temperature is 24.1 degrees, both bedroom windows are closed, the house state is home. Then the time goes into the AC_High range. That should trigger the event AC logic on high ?
It doesnt. Nor does it trigger the AC logic on event. These event s should just flick a virtual switch which then turns on my AC. If I trigger one of the events manually, the AC comes on. Once temperature goes below the specified temp, the AC turns off. When during the night it goes above the trigger levels for AC logic on, that event fires and turns the AC on !
So the AC logic off event works as intended.
The AC on or on high do not trigger the first time when the time goes into range, but after they work.
