So yesterday apparently our A/C quit working around 4pm and it went from 82 up to 84 in the house until we noticed it (4 hours later). So I am thinking of creating an event that will alert us via pushover and voice announcement in the house when:
1) The A/C is cooling (maybe for at least a set amount of time? 1hr?)
2) The Ambient temperature on the thermostat is going up instead of down.
I know I can do the first one as a condition to the second one, but I am having some confusion on the best way to handle #2.
I could set up a virtual device and when ever the A/C temp changes I could:
1) Check if the temp is higher than it's current value, if so add the condition (#1 above) and then alert us and set the virtual device to the new value
2) If the temp is lower (or the same if that's possible), just set the virtual device to the new value.
I know that "would" work, but I was kinda thinking I could get away without using another virtual device that would literally just be a copy of the current ambient temperature device from the Nest.
I looked in the easyTrigger triggers and didn't see one that would let me compare the old value to the new one in terms of greater than, less than, or equal to. Is there something else I could use or should I just suck it up and use the Virtual device?
(Note, I'm going to put in a feature request for easyTrigger to do the comparison between old and new values by GT, LT, or EQ).
***BTW, it was just that our compressor started to run backwards after a short power outage and it overheated. After it cooled down over night, it was fine. The A/C Guy says it's rare, but it can happen due to very short power outages. Not sure if he's talking out is A$$, but I tend to like and trust the guy (He's been good to me over the years).
