Recurring Event w/ Condition
    Probably really simple but..
    I want an event to run every minute, and if a counter's value is greater than zero run a script.
    This event only runs once, even though the counter is greater than 0.
    Can anyone explain to me where my logic is flawed?
    What I'd really like to do is call the script once a minute if the counter is greater than zero, but I'm not sure that is possible. Just getting this to run would work for me.
    Don
    I just built this event and the time is spoken every minute as long as the counter is not 0
    Is there any chance your script is not recognized as being finished or is not finishing? Maybe deselect "Only allow a single instance to run at a time" or try some other action?
      On second look at your screenshot, it looks like you are using a counter device instead of the actual counter. You should change the AND IF to actually look at the counter
      rather than the counter device.
      The HomeSeer devices seem to behave differently than the actual counters, it could be a bug.
        Thanks Randy:
        That seems to work. "Value has exceed this" is what I needed.
        Don
