Device value has been in the range for at least
    Hello,
    I have a problem setting-up a simple OFF timer event for a device.
    The device values are:
    0 = OFF
    1 to 254 = DIM
    255 = ON
    I want to create a simple event such as
    IF device value has been in the range [1,255] for at least 4 minutes, then turn off device.
    I upgraded to the latest HomeSeer stable version (3.0.0.297)
    However, when I select the event condition "device value has been in the range for at least", there is only one value for the range. I tried to enter 1-255 or [1,255] etc... for the value but HomeSeer doesn't understand.
    Any idea ?
    stipus
    In HS2 it was 1...254
    Peter
    http://ohh.pcgsm.nl
      Thanks for the info. I just checked and it doesn't seem to work with HS3
      stipus
        FYI, the EasyTrigger plugin has a trigger called "This device's value has been in range [X,Y] for exactly..." that can help with this problem.
          You can also use bigger than 0.
          Verstuurd vanaf mijn SM-G935F met Tapatalk
          Peter
          http://ohh.pcgsm.nl
            It could be a solution, but I couldn't find a trigger condition such as:
            "has been > value for at least..."
            I want to create a simple "OFF Timer" for a bulb... and I really don't understand why I can't create such a basic home-automation task easily.
            It looks like it's a HomeSeer bug as the HomeSeer label for the condition is "device value has been in the range..." and then there is no way to enter a range.
            --> I did open an official Bugzilla ticket for this problem.
            stipus
              How about
              IF this device had its value set and is not 0
              THEN remove delayed device actions for <device>
              THEN set device <device> to OFF
              after a delay of 4 minutes 0 seconds
              This event runs at the time the light is turned on, or changed. It schedules a temporary event for 4 minutes in the future. If the light is changed before that time (made brighter for example), the temp event is deleted and another one scheduled. So the light stays on 4 minutes since last change.
