How do I get correct time format in emails?
    I have some events that send emails and I'm using the $time variable to embed the current time in the email. This comes out in 12-hour format despite my system being configured for 24-hour time and the HS3 web UI showing me 24-hour time.
    How do I get the time in my emails to not be 12-hour?
    A couple of options that I see are to create a virtual device that holds the time in the format that you want, and the other one is to send the email through a script as you can format the time in the script more easily.
      Thanks. Is there some easy way to set a device's status string to the current 24-hour time without learning HS scripting?
        You can create an event to run a single line script. The single line script to use would be:
        &nhs.SetDeviceString(6372,DateTime.Now.ToString("HH:mm"),True)
        Run the event once a minute, referenced to the top of the hour and change 6372 to the reference id of your virtual device.
        Cheers
        Al
          Awesome. Thank you!
            Awesome. Thank you!
            You're welcome. On further review, it will be better to use this function as it generates no log entries:
            &hs.SetDeviceString 6372, FormatDateTime(Time,4),True
            &nhs uses a vb.net script and when it generates those, there's an entry in the log every time. Using &hs uses vbscript which does not generate the log entries. The syntax for the vbscript call is a bit different.
            Cheers
            Al
              Oh, even better. The logging was getting annoying, and my searches told me there was no way around it.
                I put in a Bugzilla for it to see if HS can add a way to suppress those as well.
                Cheers
                Al
